Thread: New car
    Regular Member jammydodger's Avatar
    lancashire
    Default New car
    Have ordered my new car 2 weeks ago to replace my hand me down. and was just wondering if anyone had fitted one of these !
    http://www.justkenwood.co.uk/stock01/kosa200.asp
    i was thinking of using the usb part, as you can pick up usb hard drives cheap, and you can hide it in the car without having to remove it everytime you leave the car like an ipod. and if it does get nicked its £30 gone instead of a £200 ipod
    Last edited by jammydodger; 31st August 2007 at 09:31. Reason: can't get image to show
    Nicking Ya Dinner.
    Anyone feel free to correct me here, but I don't think a bare HD is going to work, for one you will need to power the HD which will be expecting a mains supply not a car one, no doubt there is a way to convert the power source to the correct one but it will mean another unit etc, and how will you select tracks if there's no suitable O/S on the HD.
    lancashire
    Most of the slim line drives power from the usb port and the kenwood unit is supposed to read mp3 files, failing that i can just use an 8gb memory stick, which is still cheaper than an 8gb ipod. I think thats the way the usb port on these devices work but i dont know anyone who's got one.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    The 2.5" drives are usually powered by a USB port, however sometimes laptops can't provide enough power from a single USB port so have to have additional power - the 2.5" drive I carry around has an additional USB plug on its cable to plug into another USB port to provide the extra power.
    Therefore you may or may not find that the HU can provide enough power to it.
    As long as the drive is formatted and arranged in a way that the HU can understand it (probably FAT32) there should be no difference between a 2.5" drive and a USB stick - unless the HU can only see up to a maximum size (ie 8GB).
    Best to check through the owners manual to check on the specs.
    lancashire
    Thumbs up
    cheers Juzzyd i will have to check that out before i buy
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    hard drives will be low voltage not mains, PC's only have 12v & 5v supplies from the PSU. i'd go with the memory stick
