Results 1 to 2 of 2
Thread: Fuel tank cleaner
    Larkhall
    Default Fuel tank cleaner
    Over the past few days i've noticed the car isn't as quick at picking up speed as it usually is. I've been thinking it could be because the fuel tank is full of **** and needing cleaned.
    I usually fill it every week but lately it's never been over the 1/4 mark. Going to fill it tomorrow and put in a cleaner, but whats the best one to use?
    I've had the tank and injector cleaner from Halfords a few times, but haven't really noticed a difference. Are you supposed to put the cleaner in before or after you fill up? My tank is just under 1/2 full.
    Regular Member jammydodger's Avatar
    lancashire
    put the cleaner in first as when you add fuel it will mix quicker than if you add it after you fillup. have you tried filling up with super plus ( or 98 octane) unleaded every forth tankfull. with some engines this makes a big difference. if it does buy an octane booster instead of cleaner and or vary the type of petrol you use, as most of us fill at the same garage regularly try and stick to shell or bp, esso etc i found shell to be better than the supermarket stuff
  1. Fuel Cleaner
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2009, 23:05
  2. Bad tank of fuel?
    By altitude2k in forum Engine & Drivetrain
    Last Post: 8th December 2009, 14:49
  3. Oil in fuel tank
    By ianh in forum Engine & Drivetrain
    Last Post: 10th January 2008, 22:29
  4. Fuel System Cleaner
    Last Post: 13th November 2007, 16:57
  5. Fuel System Cleaner
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2007, 15:43
