Thread: Rear Window Washer?
    Regular Member PTC8's Avatar
    East Yorkshire Nr Hull
    Default Rear Window Washer?
    Is the rear window washer supplied via a different washer bottle other then the one in the engine bay.
    If not ...... mines broken
    Many Thanks
    Paul
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    No, both front and rear come from the same reservoir in the engine bay. Single pump too.
    Has the pipe become detached from the nozzle in the aerial base? (wet roof lining) or has the non-return valve malfunctioned (keep rear washer on for ages before it finally comes out)
    Do the fronts work well? Is rear nozzle blocked?
    The roof is dry and if i do keep it on for ages then it does come out a little.
    Full Member Big Sig's Avatar
    Sounds like the filter in the bottle is blocked. If it is you need to remove the wheel arch liner and pop the pump out to clean the filter. Stealers charge about £20 for this. Have you noticed that the fronts don't work as well as they used too? not making the spray they used too?
    The 2 front ones work spot on. Its still under warrenty so i think i will give the dealer a call.
    Paul
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by Astrase20 View Post
    That's why I asked about front washer performance.
    If it's covered by warranty, then let them have a look at it
    I thought mine worked spot on until I had the filter cleaned. If it is the filter its not covered by the warranty, but if its a good dealer they will do it FOC.
    Feb 2007
    Midlands
    Just a quick heads up with this, non of mine were working , front , back headlights, etc went to VX I knew what the problem was told them and thought no prblem this will be covered on warranty they carry out what you call an investigation to confirm the problem, my problem was a fuse had blow, this cost me £30.00 + VAT
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    expensive fuse. But if you knew a fuse had gone, why take it to VX?? why not just replace the fuse?
    Regular Member David_SRi_2.2DTi's Avatar
    Jun 2007
    Leeds
    Quote Originally Posted by PTC8 View Post
    Many Thanks
    Paul
    ...I had exactly the same problem, discovered it when I'd had the car a fortnight. Turned out to be the tubing had come away underneath the wheelarch, dealer repaired it foc
  1. Rear window washer
    By Ginge7289 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 23:00
  2. Window Washer
    By dc6839 in forum Bodywork & Interior
    Last Post: 26th January 2011, 19:14
  3. Estate headlight and rear window washer problem
    By henryf in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2010, 22:17
  4. water bottle for rear window washer
    By hovis007 in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 12:38
  5. window washer not working
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2009, 15:29
vectra c rear window washer
