Results 1 to 10 of 18
Thread: For those disconnecting battery with ESP!!!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Default For those disconnecting battery with ESP!!!
    "4.) Calibrate Steering Angle Sensor (Vehicles with ESP)
    Note: The ESP-steering angle sensor must be recalibrated each time the battery is disconnected from the on board power supply. The calibration can be undertaken using either of the two modes of procedure described below.
    1. With ignition "ON", turn steering wheel to its full extent from left to right
    Regular Member VectraV6CDTi's Avatar
    Wilts
    Never heard of that one. What happens if you dont do it? My battery has been off a few times and never had to do that.
    Where did you get this information from?
    You missed a bit from your post Rushy?
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by VectraV6CDTi View Post
    Cough, cough. I could tell you but site rules if you know what I mean.
    The other option was to Tech 2 it, and as we can't do that...
    It doesnt actually say what happens if you dont, but I presume its for the different settings for the sort settings.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    I can confirm this, it is one of the general security-instructions concerning vehicle electronics on Opels.
    It will not disturb normal driving, but probably important if the ESP kicks in (don't know exactly how) AND the sensor is used by the navigation system: when no signal is available (for instance in tunnels) it uses the Sensor to hold the right direction
    spoons
    Guest
    Quote Originally Posted by sig63 View Post
    This is ONE modification I really wish I had... ESP (Essential Spoons Protection)
    Melbourne, Australia
    I think you forgot to quote the bit that says which vehicles this applies to, i.e. only Corsa-C and Meriva - not Vectra C.
    Regular Member Neil's Avatar
    Feb 2007
    The pool
    Quote Originally Posted by spoons View Post
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Is that definately not applicable to the Vecy, as I have ESP and did disconnect the battery just last weekend...
    I'd ask my local dealer but I fear they would ask me to spell ESP for them.....
  1. When disconnecting the car battery.......
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2018, 14:54
  2. Disconnecting the battery
    By badge25 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd June 2007, 12:40
  3. Disconnecting battery...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2007, 23:06
  4. Disconnecting Battery
    By Neil in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2007, 18:12
  5. disconnecting the battery!
    By carl bear in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2006, 22:17
