Thread: Gearbox needs re alignment can it be done ?
    Regular Member CdRsKuLL's Avatar
    Aug 2007
    Bolton
    Default Gearbox needs re alignment can it be done ?
    ok, just got the car and I've found I need to align the gearstick stops.. If I push the gearstick all the way over to the left (without lifting the reverse lever) it wont go forward into 1st, I need to move it back a touch towards the centre.. then it will go into first.. below is a simple pic explaining whats going on.. (if it helps)
    the red line is the movement of the gearstick.. can I shortern the left stop ?
    cheers
    Steve
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    It might be that he cables need adjusting?
    Should be adjustable on the selector mechanism under the stick. Bit tricky to do IIRC so maybe one for a dealer if you're not too hot with that sort of stuff.
    Aug 2007
    Bolton
    Hi all, I did remove the gator and have a look. I couldnt see any obvious adjustments.. but did see metal rods etc.. is it easy to adjust ? I am fairly handy so i'm happy about having a go myself if pointed in the right direction.
    [off topic]
    this is a car I'm building at the mo.. so I dont mind getting my hands dirty if I know what nut to turn :-)
    [/off topic]
    cheers
    Steve
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Just had a look and its a right job. There is no way I could describe it to you and I dont know how to copy and past it from that format. Duncan, ive seen you do it before, I wont mention the software could you possibly do it? Its not under field remedies but under "clutch/ transmission" and the adjustments.
    This should help.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    TKS D, didn't know how to do it and if I was allowed.
    member of the smoke patrol 230bhp+
    lovly kit
    Aug 2007
    Bolton
    Thanks too all of you :-) will have a look tomorrow see how tricky it is.
    Steve
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Trying to Get Alignment Done
    By Jezzy in forum General Chat
    Last Post: 3rd March 2010, 12:49
