Results 1 to 10 of 16
Thread: Vectra Headunit Install - help!
    May 2007
    Perth, WA
    Default Vectra Headunit Install - help!
    Hey, im new to the forums (been lurking around for a bit).
    Ive got a 2005 Vectra Hatch, and living in Australia means most parts for aftermarket stereo's, etc are impossible to find except for ebay.
    Recently decided to purchase my first headunit for the car and bought a fascia plate and iso lead like this one: http://cgi.ebay.com.au/Vauxhall-Astr...QQcmdZViewItem
    Now I also bought a Pioneer headunit. Ive joined everything up and I'm left with 2 wires from the headunit.
    1 is labelled ILL and is for connecting to a lighting terminal. I have no idea where this would go.
    The second is labelled ACC, now from what I understand the vectra doesnt have an ACC mode on the ignition, so the pioneer instructions say connect to ignition cable. Don't have one of those either.
    What should I do. Ive tried turning it on, to no use, fuses aren't blown or anything. Do i need to connect these 2? If so where to? If not what could be wrong with the setup?
    Sam
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The later vectra has can-bus wiring so there's no ignition feed (acc) and possibly illumination,the best place for the ignition feed is the cigarette lighter and possibly the lighting feed as well(if you haven't got one fitted still check in case the loom is there).Not sure about the turning on only thing is to check to see if the power wire is still live.
    Regular Member Karl's Avatar
    Sunderland
    TBH I didn't bother with an ignition live for mine, all I did was plug the "connect 2" iso adapter in and all worked....
    If you need a live though I would pick the fag lighter.
    May 2007
    Perth, WA
    cheers for the help guys, good to know its not those two wires causing problems... so how can I check if the power wire is still live?
    Jul 2006
    I had a pioneer HU too....the permanent live wire was free, not connected to the ISO block, and it said in the installation manual to hard wire this lead to the live feed.
    Has your HU got the 2 bullet connectors so you can connect the switched live (ACC) to the permanent live? Might be worth doing that if you haven't already.
    May 2007
    Perth, WA
    nope, didnt come with anything like that...
    itss a 7850BT for reference...
    Jul 2006
    Nice looking unit
    May 2007
    Perth, WA
    yeah best part is the bluetooth, allows make/take calls, music streaming, etc... great feature
    Anyway I think Ive found the problem:
    I didnt connect the aerial, as stupid as it sounds I havent got the adapter yet (didnt come with the rest of the stuff I bought, completely slipped my mind)... and after asking a well-advised friend, apparently not connecting the aerial may mean the unit never turns on...
    Anyone experienced this? Needless to say Im now looking at aerial adapters off ebay, which of the following look good?...
    This one or this one?
    Cheers for the help guys!
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    You'll need the fakra type adapter,the only reason an aerial would would allow the h/u to power up is because the h/u earths via the aerial.To check for a live buy a cheap multimeter,the safest way to do it.
    ripon
    I used this on mine http://cgi.ebay.co.uk/AUTOLEADS-PC5-...QQcmdZViewItem
    and it works fine
  1. CK3100 Install Vectra
    By ianwillo in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2011, 15:30
  2. REQUIRED - Instructions to install Sony Headunit
    By 12345 in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2009, 14:18
  3. Please need help to install headunit!!!
    By stef_tt in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2007, 08:19
  4. Dash Light Problem After Headunit Install
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2007, 09:34
  5. New Headunit Install
    By Elite2.2DTi in forum ICE Gallery
    Last Post: 1st December 2006, 21:01
