I bought these for my LWB transit but TBH I can't be bothered with installing it when the mirrors do ok! Could be a fun addition for someone?
In includes a waterproof camera and a 2.5" screen.
Both are brand new and were purchased separetly and the specs for each are below.
I only want £45 for the pair, and I will include 1st class recorded delivery with that!
Camera:
Waterproof Rear View Color Camera
Image Device: 1/3" Inch Color COMS
Color system: PAL/NTSC
Pixel Number: PAL:628x582; NTSC:510x492
Horizontal Resolution: 420 lines
White Balance: Auto
Increment control: Auto
Video output: 1Vp-p 75Ohm
Min. Illumination(3000K): 3Lux / F1.2
S/N Ratio: >48dB
Lens View Angles: 56
Storage temperature: -10 to 60
Working temperature: -10 to 45
Power Supply: DC 12V
Power current:MaxC 50mA
Weight: 65g
Definition:45mm X 30mm X 30mm
audio/video (AV) input jack, external power input jack.
Power supply: 1.AC power-AC adapter
Power consumption: around 8W
N.B- This only includes the input leads attached to the camera, you'll need to make up a power lead and get an AV lead
Screen:
Display Size: 2.5 inch (Diagonal)
Resolution: 960x234 = 224,460 pixels
Color System: PAL -4.43, NTSC-3.58 (Auto Switching)
Signal Input: AV Signal
Input Voltage: DC9-12V
Power Consumption: <= 5W
Dimension: 82 x 60 x 26(mm), 40mm for base
