Results 1 to 2 of 2
Thread: Water leakage on GSI 3.2V6
    Jun 2007
    Kilmarnock
    Default Water leakage on GSI 3.2V6
    Hi all,
    Just reveresed out my driveway and noticed a puddle of water. Seems to be dripping from near the back of the engine compartment (nearside). Clean water, no oil evident. any ideas what it could be? Done around 52K on my '02 GSI. No probs with temp (yet!!).
    Refilled water bottle (for windows) last night but didn;t overfill and this is on opposite side so don't think its this.
    Is water pump around this area?
    Sorry about vagueness but i'm, just in at work (nightshift) and not had a good chance to look at it in daylight and just wondered if anyone else has had this.
    RoddyKFC
    [Ex]Admin Duncan's Avatar
    Have you had your car on the drive with the engine running and air-con on? Could just be the drain from the air-con unit.
    Do a test - leave the car running with the air-con running and look under the car, you'll soon see a drip if water coming onto the ground. If that matches up with where you've seen the other water then looks like problem solved.
  1. Oil leakage 1.9 CDTI 110 kW
    By Longdude in forum Engine & Drivetrain
    Last Post: 24th April 2012, 21:01
  2. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  3. Power steering rack leakage
    By Luke52 in forum Suspension, Wheels & Brakes
    Last Post: 19th November 2009, 00:32
  4. Amp Leakage from battery?
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2009, 13:33
  5. When I was checking for oil leakage...
    By haegwani in forum Engine & Drivetrain
    Last Post: 21st May 2007, 21:52
vectra 3.2 gsi water leak
