Thread: earth connection
    North West
    Default earth connection
    Where would be the best place to connect the earth wire to for the foglights.The wire comes from the relay so i need to connect to earth somewhere close to the car battery
    also y i'm on,is it OK to connect the negative from the fog units directly back to the battery negative terminal? or should i connect to somwhere else
    Jul 2006
    Mexico
    Well mate the hole chasis it`s your negative pole...so choose the spot drill a hole an bam! you are done.....if it`s to close to the battery there are some wires allready gronded to the body work in the area if I recall correctly.....on the hand other I see no problem of using the negative pole of the battery itself.
    North West
    many thanks BlueRob it's best to be safe than sorry thanx for the info don't wanna blow my car up
    I got my fogs working today took me about an hour to work out where all the wires go,connected them up then hey presto lights come on.At least now i know the job is safely done cheers bluerob!!
    Jul 2006
    Mexico
    Any time mate
  1. Bad earth
    By dezzyb66 in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2012, 15:32
  2. Earth/ GND
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2011, 20:28
  3. what on earth
    By ant6566 in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2010, 20:01
  4. amp earth
    By sristeven1 in forum Electrical & ICE (including SatNav)
    Last Post: 8th March 2009, 02:07
  5. Earth connection in boot
    By Ian T in forum Electrical & ICE (including SatNav)
    Last Post: 2nd May 2007, 02:39
veçtra c hearth conections
