Results 1 to 3 of 3
Thread: Windscreen Washer Motor
    Feb 2007
    Midlands
    Default Windscreen Washer Motor
    Have a problem with the Screen washer, not working at all the motor seams to have packed up, does anyone know if this is covered on the warranty.
    Am I right in saying that it is electrical it may have just blown a fuse?
    If it is the motor does anyone know the cost, it happened while I was cleaning the system through due to the smell through the aircon, have it booked in with VX on Thursday just looking for a heads up
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    Is there still a noise when you pull the stalk?
    Check that the filter on the washer motor is not blocked.
    Nearside front wheel/behind the bumber is the bottle...the pumps are located there...check the rubber grommets/filters where the pump push into the bottle.
    If blocked just cut them and no more problems.
    Feb 2007
    Midlands
    Hi Thx
    Had all of that off when I drained the system and flushed it through there is no sound at all when you pull the stalk, this is what makes me think it has to be electrical or the motor
  1. windscreen washer help
    By neill in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2013, 08:56
  2. Windscreen washer
    By hadiislam in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2012, 21:33
  3. Windscreen washer
    By Alansvecky in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2011, 12:46
  4. windscreen washer bottle
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2011, 13:32
  5. Windscreen washer problem
    By heheshamon in forum Vectra C / Signum Troubleshooting
    Last Post: 7th February 2010, 14:54
