Thread: Electrical Fault !
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Question Electrical Fault !
    Asking on behalf of a workmate, does anyone know what may cause the horn and steering wheel audio controls to stop working ?
    On a '03' reg 1.8 petrol SRI. All fuses apparently ok . Could it be the relay ? If so, which one/where is it ? Anything else it could be ?
    Cheers guys .
    spoons
    Guest
    ... is the key in the ignition
    spoons
    Guest
    ... is it under water
    Jan 2006
    Skynet HQ EMEC#5
    It could be bad contact points or loose connections behind steering wheel in column
    Jul 2006
    Mexico
    A bad connection on the electrical plugs mate...have you checked on those?
    Arggggggggg.....Ian beat me have to learn a fast typing or something.....
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    I reckon it will be a plug come out of the 'clock spring' as we used to call them. Basically the disc part behind steering wheel that connects those along with the airbag to the main wiring and allows the wheel to turn without snapping wires.
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    Cheers, will have a look for him later tonight.
  1. electrical fault
    By bappy in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2012, 18:44
  2. electrical fault please help
    By adamuk14 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2012, 01:26
  3. Possible electrical fault...
    By Higgsie1 in forum Engine & Drivetrain
    Last Post: 14th October 2011, 04:07
  4. Help (Electrical Fault)
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2010, 19:54
  5. electrical fault
    By :LeeR: in forum Electrical & ICE (including SatNav)
    Last Post: 24th April 2008, 18:14
