Thread: help! those with lowered suspension.
    Regular Member kev bux's Avatar
    Jan 2006
    BOROUGHPETER
    Unhappy help! those with lowered suspension.
    hi,
    ok i have had koni suspension kit fitted on car now since march/april.
    does anyone still get any creaking from the springs,thudding from suspension.
    i have recently fitted new spring mods to both sides and drop links and anti roll bar bushes. i have tried grease under the spring mod to help the springs back into the seats but noise bstill there. mainly getting the creeking when pulled up at junctions and about to pull away as i am steering.thudding is mainly passenger side over bumps.
    ****** annoying, i just want it to be peacefull.
    any ideas.
    Silly question i know but did you put the bump stops back on ......I only ask cos when i changed mine i didn't and had exactly the same symptons till i put them back on then all went quiet !!!!
    Jan 2006
    BOROUGHPETER
    yeah mate, i got 4 in the kit but only fitted one on each side, dont have to fit two each side do you(surely there would be no travel in the shox).
    the thudding is on the passenger side but earlier on i sprayed some wd40 on the rad mount springs and went for a spin and it didnt go away but it didnt sound as bad.dont think it is the struts now, sounds more like something under the bonnet? i aint got a clue.
    Jul 2006
    I've got Eibach springs on, with the spring seat mod, and I still get the occasional 'boing', but it is only occasional.
    Jan 2006
    BOROUGHPETER
    now this is weird,
    jacked the car up this aft to put some grease in the front suspension seats to help the spring mod from creeking. i took the spring mod off and thought, im gonna try the car without it fitted, so i still put a little grease on the seats and round the block i went. ABSOLOUTLY PEACEFULL,NO NOISES AS YET, TOUCH WOOD. when i fitted the koni's from new it was noisy as hell,so i bought the spring mod, made it better for a while but now i don't need it.
  1. XP2 lowered suspension
    By i320 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 21:35
  2. Lowered rear suspension.
    By felixx in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2010, 21:54
  3. lowered suspension
    By davidallanmcdonald in forum Suspension, Wheels & Brakes
    Last Post: 14th June 2010, 03:05
  4. Lowered suspension bottoming out HELP?
    By dogstar in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2009, 14:55
