Thread: How to replace car battery?
    Regular Member danlat1415's Avatar
    Lancashire
    Default How to replace car battery?
    After having a few electrical difficulties, decided to get an uprated car battery. (electrical problems when running a lot of things. HIDs + uprated bulbs all round fogs, reversing kit, SatNav etc.)
    The recommended for my car is: 60-80Ah, 540-780A.
    Currently running 55Ah, 525A. (255mmx175mmx175mm)
    Fitting 72Ah, 700A. (278mmx175mmx175mm)
    How exactly does the battery come out? Not picked battery up yet, so won't be doing it for a few days, but just want to prepare.
    The battery is the same size height and width, but 2cm longer. It will fit, because there is a sliding clip holding it it place to adjust for different lenth batteries.
    What i've got so far:
    Disconnect negative, disconnect positive... then what?
    Is the battery bolted in anywhere, or just clipped in?
    Full Member Big Sig's Avatar
    There is one bolt on a clip on the engine side of the battery. Just undo it, remove the clip and lift the battery out. If you think that is big you should see the battery on the 3.0 V6 cdti!
    Jul 2006
    Mexico
    By any means avoid sparks!
    Lancashire
    Also make sure that you put all the cables back on the right terminal. Some live - red ones - are sometimes black like the negitive ones. I'd connect the neg first.
    Feb 2006
    Guttedsville
    Make sure the doors are unlocked, the drivers door open and the keys in your pocket!!
    I'm sure cars have moved on a bit, but theres always a chance something silly may happen!
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Quote Originally Posted by AndrewTi View Post
    Good advice there! Had interesting moment with my old Peugeot 405 - fortunately disconnecting the battery and reconnecting it unlocked the doors...
    Jul 2006
    Mexico
    Quote Originally Posted by Astrase20 View Post
    I usually reconnect the other way around mate.....first positive and then negative....inverse order from the disconnect proccess...
    Lancashire
    Connecting the terminals back up correctly should be fine. On mine they are connected to a block, then the block is connected to the battery terminal. So when I remove them, they are still all connected together ready to connect back up.
    Disconnected the battery before, but never replaced it. The doors auto unlock when the battery is connected.
    Always good advice to leave the driver door unlocked and open when messing with the battery, just incase.
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
  4. Tie rod replace
    By blackveccyC in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2010, 15:15
  5. Alternator failure, but shall I replace battery too?
    By ishaqmir in forum Engine & Drivetrain
    Last Post: 11th February 2010, 16:09
how to change car battery in vectra c
