Thread: Drivers Door
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    Angry Drivers Door
    im getting a warning on the display saying my drivers door is open , but its not , the roof ights are stayig on and the central locking wont lock when i press the button on the door ......... all advise /pics welcome
    Steve
    Nicking Ya Dinner.
    Sticky sensor, I'm not sure where it is, but I think it's on the B piller iirc, have a look and push it in and out a few times. hth.
    Jan 2006
    Hornchurch
    its just the push sensor thing on the front door take it out an give it a clean your need a torx bit set
    [Ex]Admin Duncan's Avatar
    It'll be the slam plate (or whatever it's called) - the bit on the B pillar that the door lock clicks into. Sounds like it needs adjusting a small bit to stop that. Do it in small amounts until the light stops coming on.
    Apr 2006
    Wigan
    were is the push sensor in the door
    Not sure what he meant by push sensor. As far as I'm aware the door closed sensing system works on an electrical contact principle, hence the bit about adjusting the slam plate. I'd certainly try that first, that's what I did when mine popped up one day on the tailgate.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Isn't it a switch in the lock mechanism??
    Could be Ste, buried inside - certainly not easily visible. Maybe once you pop off the two large Torx bolts on the door lock (possibly what Danny was referring to) it'll be visible. My money's still on a small adjustment to the striker plate though.
    Apr 2006
    Wigan
    was a build up of sticky old grease in the lock mech this has aswitch in it , i blasted it with brake cleaner then gave it max with a tin of lube , worked a treat , thanks for all the pointers
    Regular Member graham a's Avatar
    hull
    glad your sorted steve,when this happened on my last veccy c,they changed both the front locks under warranty and the key fobs?
  1. Removing my drivers door.....?
    By houston in forum Bodywork & Interior
    Last Post: 9th October 2012, 22:24
  2. drivers door switches
    By Rickiw in forum Electrical & ICE (including SatNav)
    Last Post: 10th January 2010, 10:11
  3. Drivers door not flush
    Last Post: 28th November 2009, 20:50
  4. drivers door clicking
    By scotty6w in forum Bodywork & Interior
    Last Post: 28th September 2007, 16:34
  5. Drivers door switch
    By daviek in forum Parts for sale
    Last Post: 24th September 2007, 12:56
