Results 1 to 10 of 14
Thread: how to reset the inspection indicator
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default how to reset the inspection indicator
    hey guys just picked up my 1st vectra tonight and it has been serviced my the dealer but not a vx dealer but when i switch the car off the inspection indictor comes on. so i know it doesnt need serviced so how do i rest it. 1st post so far but i plan to have loads more lol
    [Ex]Admin Duncan's Avatar
    Turn ignition off
    Hold trip/odometer reset button - keep holding
    Turn ignition on
    Keep holding reset button until the odometer display does a little 'dance' - should now be reset.
    BTW!
    Aug 2007
    Lisburn, N.Ireland
    all that happens is the inspection light flashes and under it are dashes like this- - - - - . as soon as you let go it goes to the normal display and when u take key out the inspection display comes on again . will post pics soon
    How long are you holding button for once it does the ------ before you let go?
    You need to keep holding it while it's got ------- on the display until they go away.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by aerodynamic18 View Post
    As it is facelift you need to push the brake pedal while you see the --------
    Ah, is that where the brake pedal comes into it? I'd seen it mentioned before but didn't see the relevance as I didn't need to do it when I reset mine (being a pre-facelift).
    Aug 2007
    Lisburn, N.Ireland
    so let me get this. i put key in and press brake and reset button then turn on ignition. do i start car or just till its about to start and how long shoud it take? thanks 4 the help guys
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    no don't start, see: http://forum.vectra-c.com/showthread.php?t=14593
    Aug 2007
    Lisburn, N.Ireland
    thanks guys all sorted happy days
    also it is a 1.9cdti 150bhp wit 24000miles on clock and while drivin i have never really see the engine temp get near to the 90 degrees is this right or whher should it sit. its usually to the left of the 90 mark
    Not sure if the 1.9 is any different, but mine (2.0T) sits happily on 85 degrees 99% of the time
  1. Left indicator flashing fast, front indicator not working
    By Hummelshøj in forum Electrical & ICE (including SatNav)
    Last Post: 7th August 2017, 14:42
  2. 'Service Due' Indicator reset question
    By wafoo in forum Engine & Drivetrain
    Last Post: 2nd June 2012, 00:38
  3. inspection indicator
    By matt.t in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd June 2011, 20:35
  4. inspection indicator
    By kamar in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 11:28
  5. reset service indicator
    By johnturbo in forum Engine & Drivetrain
    Last Post: 5th October 2010, 14:01
vectra c prefacelift inspection
