Thread: orange engine warning light
    Regular Member markvec's Avatar
    livingston
    Default orange engine warning light
    my sisters vectra b estate 2001, any clues as to what it could be , it came on when she was driving and hasn`t gone off since, car drives and acts normal, no stutering or loss of power, just a light ,
    any ideas peeps cheers mark
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Is it the EML light.
    If so, it may have gone into limp mode, wont rev past 3500 repm, but drives pretty normal other than that.
    What engine is in it, if its petrol 1.8/2.0, my old one used to eat Cam/Crank sensor's for fun!
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    Its logged an error or then is an error still active, without doing the paperclip test or having fault codes read cant be of much further use to you..
    livingston
    shes just told me it`s slugish after 3000 rpm so its in limp mode soooo... how do i know if it`ll be the cam crank sensor and how much to fix
    cheers for the quick reply
    feel kinda guilty as we sold her the motor only a month ago
    how do i paper clip test
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    just realised yours will be the facelift version and paperclip test may not work
    Looks like a trip to a friendly garage with some fault code reading equipment..
    Jun 2007
    Quote Originally Posted by markvec View Post
    As McPlasma said, you need to have the codes read by someone with a Fault Code reader. Some independant garage's have them, if not i would think it would be main dealer. As for cost, if it's the Cam Sensor, then they are £45 from Vauxhall, then the cost of fitting it, or you can get a pattern one from Partco for £29, thats what i paid just before Xmas for a 2.0 SRi.
    IIRC the Crank Sensor was about £95 from VX when i did my old one, not sure if pattern one's are available tho.
    But first and foremost, get the codes read, as i could be barking up the wrong tree!!
    livingston
    it is facelifted mate, booked into a vxl dealer on thursday but if i could bodge it and/or dodge it first to save pennies all the better
    i`m just a panic merchant and always fear the worst when vauxhalls are concerned
    thanks for the replys guys will take it out to a few garages tomo and see if they can help... bl**dy electrics eh
    Jun 2007
    If it is a Cam/Crank sensor, ask them how much to fit it if you supply it, could save yourself a few quid that way.
    livingston
    is there a fuse to pull to deactivate the light and reinsert incase the fault it found no longer exists , does that make sence ??
    You could try disconnecting the battery for half an hour or so. Just make sure you have the radio code etc.
  1. Orange/Yellow Oil Warning Light
    By countduckula55 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th July 2011, 17:44
  2. Orange warning light (engine shape) 2.0t
    By Zero in forum Engine & Drivetrain
    Last Post: 11th April 2011, 19:45
  3. Orange light of Engine death......or not?
    By Keefyb007 in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2010, 22:03
  4. Orange Engine Light
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 00:47
  5. Quick Q? Dash warning light orange circle in brackets?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2009, 15:20
