Results 1 to 10 of 15
Thread: Induction kits for 2.2DTi
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Default Induction kits for 2.2DTi
    morning all
    what difference do these make..... if any.....
    http://knperformancefilters.co.uk/k-.../prod_631.html
    cheers fellas
    russ
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Not too sure on the induction kits, but i have had the air box mod done and it certainly made a difference to my car, especially on cooler nights.
    Mar 2007
    Grimsby, Lincs.
    what is the air box mod mate?
    Jun 2007
    Basically when you open the air box, take the air filter out, and where the air pipe comes into the base of the air box near the front of the car, there is a flat piece of plastic about 3 inches long covering the hole. Just snap the piece of plastic out.
    Somewhere on here there are some photo's/link/how2, will have a look for you.
    Jun 2007
    Here you go, found a picture on an older thread, this isa 1.9CDTi air box, but its the same principle.
    Dont forget to disconnect the battery for 30mins after you have done it to let the ECU reset itself though.
    Regular Member NeilB's Avatar
    Aug 2007
    Newton
    I'm new to Vauxhalls so please excuse my ignorance. If you disconnect the battery for half an hour - don't you lose all the radio code and stuff??? I know if I had done that on most of my previous cars, it would be a right old job of re - entering codes etc.
    Jun 2007
    Quote Originally Posted by NeilB View Post
    On my car i did lose the radio codeand had a right job getting it afterwards, but i think some car's are ok. It is best to check you have the car pass with the radio code first.
    There is a valid reason for disconnecting the battery though, it alows the ECU to re-calibrate itself for the different level of air going into the engine, or something along those lines. Its quite important you do disconnect it though.
    Aug 2007
    Newton
    OK - so I have to check that the car comes with the car pass for the radio. If it doesn't, is it just a question of asking a Vauxhall dealer for the detials? Thats how it worked with a Volvo I used to have....
    Jun 2007
    Pretty much yeah, however, My problem was the car pass i had, and the details Vauxhall had did not tally up to the radio i had in my car. It had been changed at some stage in its life(Probably by The Car Shop where i bought it from) and the new code hadnt been written down anywhere. All i did was take it back to The Car Shop and they had a code scanner they put onto it and gave me the code.
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Most 05 cars and all face lift models are full can bus and shouldn't need a code. Be aware though that electric windows might not function properly for a while afterwards. They will sort themselves out, shouldn't take more than a day.
  1. Available Induction kits.
    By Cruize in forum Petrol Engine related
    Last Post: 4th February 2010, 21:27
  2. Induction Kits for 2.8 V6
    By luke4487 in forum Petrol Engine related
    Last Post: 23rd October 2009, 17:13
  3. K&N Induction Kits
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2007, 23:30
  4. Air Induction Kits--which One?
    By armoured farmer in forum Petrol Engine related
    Last Post: 6th December 2005, 00:17
  5. induction kits
    By johnnyhg in forum Diesel Engine related
    Last Post: 24th November 2005, 23:50
