Results 1 to 10 of 18
Thread: reversing light - which wire?
    Regular Member wardy's Avatar
    Chichester
    Default reversing light - which wire?
    Hi,
    Have looked through several threads on fitting reversing sensors, but as I have the estate I'll need to trace the live feed from the reversing light which is in the tailgate.
    Has anyone done this? Where do the wires end up in the boot? i.e. where would be the best place to connect the live feed, or will i have to run a wire all the way to the reversing lamp?
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    have a look at the below thread I had the same problem....luckily I had a bypass relay.....
    http://forum.vectra-c.com/showthread.php?t=29232
    Jun 2007
    in a white box
    I used the nut to the right of the fuse box as my earth. didn't untighten fully as didn't know what it held on. unscrew slightly and you can slip a wire behind it......one earth......no scraping of paint required.
    by the way do you have the leads shown in my photo's....
    Chichester
    Cheers John.
    Is it the thin red wire in the first two pics? I can't quite make out from that picture where its connected.
    Jun 2007
    in a white box
    i believe its the thin red wire with the blue connector attached to the thicker black wire.
    I would just temp attach if possible to see if its the one. Or trace it to see if it goes into the tailgate.
    Chichester
    Ok I'll give it a try.
    Chichester
    Had a look at the fuse / connection box(es) in the rear left pannel inside the boot. My car has a 7.5 amp fuse number 28 which according to the handbook (page 219) is for reversing sensors????
    Any idea why mine would have that fuse? Has anyone else, who doesn't have factory sensors, have that fuse?
    I'm wondering if I could take the live feed from here, if the fuse only goes live when reverse is engaged.
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    See the Pic, top right hand pin is the reverse light. (amonst the clump of black wires)
    Chichester
    Sorry ghostrider, but I can't see which pin you are reffering to.
    Which connection block is it? Blue, brown etc?
    Any closer pic available?
    Chichester
    been & had a look on mine.
    near the top, just to the right of the thick red wires, there are two connection blocks with black bundles of wires going in. In your pic they would be behind the two flat ribbon wires. The top one of those blocks has 4 fairly thick black wires going into it. Directly under that there is a white block with about 10 very thin wires going in to it. Is it the top right one of these? The thick one, or the thin one?
    The thin wires look almost like speaker wire.
    Your help would be much appreciated.
  1. O/S Reversing Light
    By cosmic in forum Insignia car chat
    Last Post: 28th December 2011, 00:16
  2. side light wire
    By justyb in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2010, 18:56
  3. Reversing CAMERA -Wiring to Light help Needed
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2010, 08:22
  4. Reversing wire
    By Deano.56 in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2009, 20:11
  5. Reversing Lights...which Wire?
    By bennyk in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2007, 13:20
vectra c reverse light wire
reverse light vecta c fuse
reversing lamp vectra c
