Results 1 to 10 of 16
Thread: Warning light on dash: What could this mean?
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    Default Warning light on dash: What could this mean?
    Driving down the motorway this morning, spanner light illuminated on the dash.
    Pulled over at services and switched off. Turned it back on again and the spanner light had gone. Its done this a couple of times before and usually sorts its self out when you switch off and back on.
    However, this time, the spanner light had gone but there was another light illuminated on the dash that hasnt came on before.
    Its a yellow light, bottom of dash furthest to the right. Looks like a wee square with lines at each end. Looking up the manual, it tells you that its "exhaust emissions" warning or something?.
    What could this be?.
    I got home and took the CRD2 off and switched on again, but although the spanner light has gone, this little emissions light refuses to go out.
    Car appears to be driving perfectly normally.
    Regular Member david.aka.judas's Avatar
    Suffolk
    could it be the egr valve?
    it was on mine.
    Falkirk, Scotland
    No idea m8!!!???.
    I thought I read somewhere on here that only facelifted CDTi's had EGR valves?. Or is that something else I am thinking about?.
    What year is yours?.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by RSV_Ecosse View Post
    No idea m8!!!???.
    Think thats the particle filter your on about mate.
    Disconnect the battery for a while to reset it. The light should go out. If its emmisions then maybe a sensor has gone?
    Regular Member wardy's Avatar
    Chichester
    I had same problem on a V6 running a CRD2 box. It turned out to be the wiring loom for the CRD2.
    When you bought the box it should have come with a "blank" end that you can attach instead of the box. Try that & if it continues at least you know its not the box. Then try removing the CRD2 wiring altogether. If that solves the problem then you may need a new loom.
    Hope that helps.
    Falkirk, Scotland
    Quote Originally Posted by Astrase20 View Post
    How long does the battery need to be disconnected for to attempt to extinguish the light?.
    Wardy, I have completely removed the CRD2 for now, but the light is still on.
    Going out to check it again just now and if its still on, I'll disconnect the battery for a few hours and see what happens.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    15mins to half an hour should do to clear stored codes.
    Falkirk, Scotland
    Thanks m8, will nip out and disconnect battery just now and give it a go.
    /crosses fingers.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Any joy? Has the light gone?
  1. warning light on dash
    By tj56 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2011, 14:50
  2. Dash warning light
    By dogmorfmucion in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd June 2011, 19:37
  3. dash warning light
    By graememk in forum Engine & Drivetrain
    Last Post: 1st November 2010, 02:26
  4. dash warning light
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 4th April 2010, 17:49
  5. dash warning light
    By deano in forum Engine & Drivetrain
    Last Post: 10th January 2007, 09:02
