Thread: Removing std stereo
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    Default Removing std stereo
    How does the stereo come out of the dash ?
    It's a CDR 2005.
    Regular Member NI-2.2SRI's Avatar
    Northern Ireland
    from memory, without tryin to find my old headunit, there is four holes at each corner, think there is a small grub screw in each one, remove these then u hav to insert a set on "headunit keys" r i used a very thin long screw drivers, into these holes to release the catchs that hold the headunit in, heavy gauage stiff wire also worked for me but has to be 2 or 3 mm thick. headunit should then be able to be withdrawn. hope this helps.
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    Quote Originally Posted by NI-2.2SRI View Post
    Cheers, will give it a go.
    [Ex]Admin Duncan's Avatar
    As above, but job made easier by a set of Double DIN pullers as they have little hooks on them to then let you pull the unit out with the pullers - a few quid from Halfords.
    Here, there and every where!
    Make your own out of a wire coat hanger
    lol - true, but I certainly couldn't be faffed doing that when the right tool was only a few quid and available just down the road.
    Nicking Ya Dinner.
    And prepare for a frustrating afternoon, if it don't come straight out, go to the local ICE shop and drop a fitter a fiver to get it out for you, it seems to weld itself in after a while, but they will know the trick to getting it out. hth.
    You're not a true Scot there D
    Quote Originally Posted by VauxVeteran View Post
    Nah, no need for that VV. Piece of pee to get them out, especially using the aforementioned Double DIN puller.
    Quote Originally Posted by Caterman View Post
    - I'm all for saving a few quid where I can, but sometimes there's no substitute for the right tool, which I'm happy to stump up for when it makes the job sooo much easier. Once the grub screws are out, I can have my HU out within 30 seconds.
    6 Post(s)
    Year : 1 A.D
    Mileage : Rising
    They are approx £5
    It came straight out with some old coat hanger hooks !
    Simple question now, wheres the best place to take an ignition live from without beggering up the electrics ?
  1. Calling ICE/stereo experts.. Dvd/stereo, will this fit in my Pre-face Vec C Gsi?
    By TAB in forum Electrical & ICE (including SatNav)
    Last Post: 27th February 2013, 13:20
  2. removing stereo
    By ocean2211 in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2013, 01:18
  3. Removing the Radio / Stereo cage
    By Silly Car in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2010, 23:40
  4. removing my stereo
    By kman247 in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2009, 21:32
  5. Factory fit stereo to ordinary size stereo
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2007, 12:24
