Thread: service indicator
    Regular Member gizmo10119's Avatar
    Cambridgeshire
    Default service indicator
    hi chaps
    not been on the site for a while so had alot to read thro! and i missed the east meet!!! doh
    looking for some advice
    had the oil changed as requested by the car a few days ago (not by vx) the indicator says its due at 14k so i did it at 13500, only trouble is i cant seem to reset it, followed the guide in the autodata book but no joy any one else had this? i have done it in a previous vec c and it worked fine but not this one! its a 54 plate sri 150 cdti
    any help greatly appreciated
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Get in,
    Press and hold the trip reset button, turn ignition to pos 2 (ie dash lights on) and continue holding for up to 30 seconds. The mileage counter should reset to 30000 (as it's diesel)
    If it's not working then it may be on a different service schedule (don't ask me why etc or how etc, it seems a bit random)
    Cambridgeshire
    thanks ste,
    i have tried this but no joy will try again tho, i have found some comments that this can only be reset with tech 2 but that does not agree with a new directive bought in recently re competition or something. ill give it a go!
    Regular Member denzo's Avatar
    Runcorn
    Depends, If you have a Particulate Filter the service indicator = 15K.
    Mine reset to 15K (and I dont have a DPF) ... Dealer spent ages and ages trying to reset it to 30K, in the end they reset it to 31K
    Need to use the long life oil though GM-LL-25A/B
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Didn't think / know about the DPF was different. Learn something every day.
    Cambridgeshire
    thats the beauty of it always something new round the corner!
    mine doesnt have a dpf, checked when i had iton the ramp
    tried the holding the trip button with ign on again but no joy
    Runcorn
    Easiest check for presence of DPF.
    On your Car's VIN/ID Plate stuck to drivers B Pillar look at the bottom LHS, if you have 0.50 then you have a DPF, if you have 1.20 then you haven't got a DPF
    Wolverhampton
    Here's the exact manual reset procedure taken from the Vauxhall Dealership manual for the Vectra C (bold type below). Worked fine for me but you need to follow to letter. Most important to start procedure with ignition off.
    Resetting the flexible service interval (ECOService Flex) with TECH 2
    The display for the flexible service interval (time and kilometres) can be reset via the instrument assembly. The engine control unit communicates with the instrument assembly.
    Manual resetting
    Ignition OFF. The tachometer display must indicate the trip odometer reading.
    Press and hold down reset button (trip odometer button)
    Switch ignition ON and wait until the service interval display changes and keep the reset button held down for at least 3 seconds.
    After 3 seconds, the tachometer display indicates the symbol with the maximum mileage, 34.000 km for petrol engine or 50.000 km for diesel engine.
    The time counter in the instrument assembly is set to 24 months. The engine control unit receives a signal via the CAN bus and the "oil condition" is set to 100 %. The engine control unit and the instrument assembly are now reset.
    Notify the customer that a service display accidentally reset by the customer can not be updated again by the Opel dealer. Depending on the mileage driven since the last engine oil change / Main Service, a new engine oil change may be necessary in order to prevent engine damage
    manchester
    Default service indicator reset
    hi all, just noticed that some were struggling a bit by just holding the trip button and turning on, the brake needs to pressed with the trip then turn on and wait about 10 secs and it will reset to original intervals. i was wondering if there is a function to pick your interval as i could on a R reg 306 and thats french!!!
    DENMARK
    The brake thing worked with my car :-)
  1. service indicator on vec 2.2
    By pinnacare in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2008, 00:29
  2. Service indicator
    By stanian in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 23:17
  3. Service Indicator
    By VauxVeteran in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2007, 20:29
  4. Service indicator
    By CPHB in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2007, 14:41
  5. Service Indicator
    By Spelly in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2007, 23:04
