Results 1 to 10 of 18
Thread: FAO ghostrider
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Default FAO ghostrider
    parking sensors all fitted.....
    Had a little bit of a panick as I couldn't locate the reversing light wire.
    guess what........my towbar saved the day......just piggybacked onto the bypass relay and hey presto......beep beep..........
    ps
    Check out my new avatar, watched it last night.......brillant.....
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Glad you finally got them fitted. Do they work OK?
    You'll need to have a look at the pictures i've attached for the connection detail.
    P.S. where did you get the pictures of me? hehe
    P.P.S If you see a Metro Blue Vectra C Estate (with rear prking sensors on) that has flames comming from the driver; driving down the M20, then give me a wave.
    P.P.P.S Where do you find the bypass relay on a cornflake box???
    On another planet
    Engine : 2.0
    Wow, thats a **** picture, but that's the 2nd connector down i mentioned (where you can see the snap on connector)
    If you need a better pic, then let me know.
    Jun 2007
    in a white box
    yes, haven't hit the garage door yet.......
    avatar site is on the bottom of the picture. if you want it you can have it. I think my little friend will be making a comeback. I miss him.
    have you traded in your harley davidson for a vectra. Wise choice
    the bypass relay was found amongst the cornflakes. Apparently its a free gift in the 2kg box...........cheers..
    Jun 2007
    in a white box
    the thick black wire you mean...
    Jun 2007
    in a white box
    found a lot of loose connectors about the place.............any idea's what they are............
    On another planet
    Engine : 2.0
    Will go and have look... 2 mins.
    On another planet
    Engine : 2.0
    Don't have any connectors like that on mine? all the connectors around the fuse box are square and plugged into something. The ones on your picture are rounded?
    Jun 2007
    in a white box
    sorry, should have told you where they are....
    the square one is at the fuse box. just dangling on its own.
    the two round ones are in the spare wheel area. the thing at the front where i store my bits and bobs.
    looking at the colours they are similar to the airbag connectors in the steering wheel...........does a airbag go off when you're rear ended. I cannot see where they would be connected too. they are definately vx.
    I'm sure one of the technical people will know. please don't pop out again in the dark.
    I'm sure if it was serious I would have some sort of warning light.....
    thanks for your help......
    On another planet
    Engine : 2.0
    What spec estate do you have? I have the SRi. Which doesn't have the option of parking sensors, so you might have a model that does, hence they may be the connectors for the factory fit sensors??
