Thread: Trolley Jack - Best location for Vectra C
    Regular Member denzo's Avatar
    Runcorn
    Default Trolley Jack - Best location for Vectra C
    Hi
    Where is the best position to use a trolley jack at the front and rear of the Vectra C ?
    I just jacked mine up using the square scissor jack guide locator, i'm sure there is a better location without putting hole in the floor
    Pics would be great ... please
    Tyneside
    I used a section just in front of the plastic locator, its a small section thats the correct size to locate the lifting arm of the jack.
    Feb 2006
    Guttedsville
    Small lump of wood on the plate of the jack that fits into the normal recess, then use the original point.
    Jul 2006
    I just used the original jacking point.....worked fine
    Full Member Big Sig's Avatar
    I usually use the inboard lower suspension arm point. Where the bush is.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by AndrewTi View Post
    That's what I used to do, but found it a little bit iffy....
    What I do now is use a larger block of wood and go under the chassis - basically straight in from that point.
    Quote Originally Posted by Astrase20 View Post
    That's where I used to put the axle stands .....
    ....but now put them under the subframe a bit further in.
    Will see if I can get some pics tomorrow as these came from my How 2 thread on oil/filter change.
    As for the rear, I simply put the jack carefully under the lower suspension arm to jack then put an axle stand further in on the arm. I'll also get a pic tomorrow if I can.
    Runcorn
    Thanks Duncan
    Do you jack underneath the bushing (the cylinder thing)? it looks quite unstable.
    More photos would be great .... cheers
    Denzo
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    I'll second that.
    Quote Originally Posted by denzo View Post
    Never jacked under it, only ever put an axle stand there so obviously couldn't jack under it as well - but as I said I now use part of the subframe for axle stands instead. Will try and get pics today.
    Luton
    Eek Jacking Points - Caution
    Be careful - what look like solid rectanglar jack head `receptacles' on the sills are in fact only bits of plastic, which plug into the bottom of the sill with a plastic `fir tree' connector. If you side load them they can pop out at an angle. Not nice - if fact ***p engineering.
  1. trolley jack
    By Swedge in forum The 'Off Topic' room
    Last Post: 13th December 2012, 19:23
  2. Which trolley jack?
    By peelmeister in forum The 'Off Topic' room
    Last Post: 6th March 2012, 11:10
  3. What trolley Jack?
    By Stevel in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2009, 15:40
  4. Off to buy trolley jack
    By shan in forum General Chat
    Last Post: 5th October 2008, 23:16
  5. Trolley Jack
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2007, 18:36
vectra c jack
vectra c trolley jack place
vectra c axle stand points
vectra c jacking at the front
vectra c jacking points
how to lift a vectra c with a trolley jack
vauxhall vectra c jack
What are the safest places to position a trolley jack on a vauxhall signum
