Results 1 to 10 of 18
Thread: Computer problem
    Regular Member silverhairedracer's Avatar
    ESSEX
    Default Computer problem
    I am sure there must be some computer whizz kids amongst us,here is my problem...
    I have purchased an MP3 player and when I connect it to the USB port [plug & play]it flags up "Device not reconised,"when I check out the device manager it shows as "unknown device",I am running XP with service pack 2 installed,
    in a nut shell.... HELP
    Which MP3 player? It mustn't be one that XP recognises. Did it come with a CD of drivers/software to install? If so, it'll need at the minimum the drivers installed, even if you didn't want to use the software.
    ESSEX
    It is a Samsung the CD has been installed but it covers the music & media,As far as I am aware the plaug and play should automaticly [? ]be reconised and the driver within starts up
    Regular Member archerz's Avatar
    May 2007
    Teesside
    Engine : 3.0 v6 CDTI
    Mileage : 57500
    try a different USB port, sometimes works. you need the device to show up as removable media in device manager. but usually can mean ****ing with searching fo drivers
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Only if the necessary driver is present in the library.
    Try install from a known location and insert CD and aim it at it
    ESSEX
    Quote Originally Posted by Ste View Post
    How do I do that ?.
    I have tried different ports ,ie the two on the front and the ones what the printer & scanner are plugged into.
    Nicking Ya Dinner.
    If you have an icon in my computer, right click it and format the mp3 player.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Can you right click on the icon which tells you it is unknown device or not working properly and install the driver from the CD, by browsing to it's location?
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    If you insert the CD it may automatically run the install program.
    Regular Member Voxer's Avatar
    Ayrshire, Scotland
    If you've tried it in different usb ports and your still getting the same problem you've probably got a fault in your MP3 player, even without drivers installed XP would tell what type of device is attached, i.e removable media, digital camera, mp3 player etc.
  1. Problem with onboard computer
    By ian124 in forum Electrical & ICE (including SatNav)
    Last Post: 25th December 2010, 14:50
  2. Got a computer problem, can anyone help?
    By purple170503 in forum General Chat
    Last Post: 1st May 2008, 17:01
  3. Fuel Computer Problem
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2006, 22:00
  4. Computer Problem!
    By Caterman in forum Comedy & Humour
    Last Post: 19th February 2006, 00:18
  5. Computer problem.
    By SCOTTEX in forum General Chat
    Last Post: 18th January 2006, 13:46
