Results 1 to 10 of 16
Thread: How do I change the dipped beam bulb?
    Regular Member johnny kebab's Avatar
    May 2007
    Leighton Buzzard
    Default How do I change the dipped beam bulb?
    Hi All,
    got a 2003 3litre V6 vectra with a blown dipped beam bulb on the passenger side. not too much of a problem, or so I thought! I know things are abit tight in the engine bay but for the life of me I can't get the old bulb out to replace it!
    Can anyone help talk me through it?
    Cheers,
    Johnny Kebab
    [Ex]Admin Duncan's Avatar
    'tis a bu**er - especially on the 3.0 as it's a big engine. First thing is to remove the windscreen washer filler pipe. Make sure there's no water at in it, unclip it from the body and just twist it to and fro and pull - it'll just pop off. That'll give you a more room to get your hand in. Then it's just a case of getting the little clip on cover off and getting the bulb off. Fiddly, but if you take your time you should do it without too much swearing!
    May 2007
    Leighton Buzzard
    I have to plastic cover off the bulb housing but I'm struggling with the connector on the back of the bulb.
    any clues!?
    JK
    Ah right - one sec and I'll refresh my memory <off to look at car>......
    Right, assuming it's definitely the sidelight at the bottom?, and not the main beam above it, then you simply take hold of the little black bulb holder and pull it straight out - simple as that.
    Edit: For some reason I thought you were talking about the sidelight bulb - gawd knows why when you've said dipped beam all along!! I think your post saying plastic cover threw me as the cover for the sidelight and high beam is plastic, the one for the dipped beam is rubber. That's my excuse anyway and I'm sticking to it!
    Right, in that case you grab the black plastic bit on the end of the bulb holder and turn anti-clockwise. A 45 degree turn should loosen the holder to let you get it out.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I changed all 4 headlight bulbs on my CDTi the other evening - it was a b*tch of a job - particularly the drivers side there was hardly enough room for my hand
    May 2007
    Leighton Buzzard
    Duncan, you're a legend! Thanks very much, all done!
    Johnny Kebab
    Jul 2006
    Mexico
    Yeah I usually take off also the air filter box cover and unplug the loom with the red clip to make a little more room in there.....its an easy job for a person with small hands
    Jul 2006
    Mexico
    Quote Originally Posted by johnny kebab View Post
    Johnny Kebab
    Hey D I think no body has call you a LEGEND before Duncan "the legend" sounds cooolll¡¡
  1. One dipped beam dimmer than the other...
    By y2joeyb in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 15:45
  2. Astra h dipped beam bulb change
    By nokiaman1978 in forum The 'Off Topic' room
    Last Post: 2nd June 2011, 16:59
  3. Full Beam/Dipped beam
    By ontoplums in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2011, 18:06
  4. Dipped beam
    Last Post: 23rd October 2009, 01:35
  5. Dipped beam bulbs?
    By Humph Backbridge in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 22:07
vectra c dipped beam
vectra c dipped beam cant get bulb out
