Results 1 to 10 of 29
Thread: My Key Remote won't work
    Regular Member danlat1415's Avatar
    Lancashire
    confused My Key Remote won't work
    I've had this problem for a while now.
    The car keys remote hardly every works.
    It's got a lot worse recently.
    I've changed the battery in the keys so I know it's not that.
    When I press the key lock, or boot open buttons nothing happens.
    Sometimes it works, and sometimes not, but lately it's got worse.
    I've been having to lock the car manually with the key (which doesn't set the alarm )
    Does anyone know what could be causing it?
    Or is something failing in the car? a sensor or something?
    I've also tried resetting the key with the car - putting key in ignition, and turning, but not starting engine, and then pressing the door lock buttons. This worked fine when I changed the battery, but makes no difference now.
    I have to get right up the the drivers window, and press the remote a dozen or so times before it works.
    Please help!
    Dan
    Regular Member Adam's Avatar
    Dunstable, Bedfordshire
    Are you sure you're trying to unlock the right car?
    Regular Member ukanalyst's Avatar
    Jul 2006
    Cheshire
    Does it change depending on where it's parked? Ie is it only when it's on your drive you have the problem? In some places I park the remote won't work until I get very close to the car ... I suspect it's caused by local RF (Radio Frequency) interference.
    Lancashire
    No, it's just everywhere.
    Even when I'm sat in the drivers seat, and press the remote, it only works sometimes. Was fine a month ago, then deteriorated in last few weeks, and now it's pi$$in me off.
    Jul 2006
    Cheshire
    do you have a spare key with remote? Have you tried that? If not when you press the button on the remote do you always feel a positive Click or does it sometimes feel a bit 'squashy' (faulty switch?) If it's the old style key remote (ie not flip key) I seem to remember it has an LED that illuminates when you press the buttons ... does this always light?
    Just some ideas.
    Dave
    Lancashire
    Yeh, I've got the old style key, and there doesn't seem to be anything different with the key than normal. The buttons click, and the LED comes on everytime. Just seems to be the car picking up the signal. Only got 1 key
    Where in the car is the receiver? maybe I can have a mess with that?
    Lancashire
    Anyone help??
    [Ex]Admin Duncan's Avatar
    You tried taking it apart and giving the switch bit a good spray with contact/switch cleaner? Maplin sell small aerosols of it.
    Lancashire
    Taking the key apart?
    No - I'll try that.
    What in the car senses that the key has been pressed? If I know what that is, maybe I can see if it's connected right, or may be getting faulty?
    Lancashire
    Tried spray cleaning the switch inside the remote, and made no difference. I have a cleaner for computer parts in a spray can.
  1. remote help
    By bigbranno9 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th January 2012, 11:24
  2. Remote Did Not Work
    By dc6839 in forum Bodywork & Interior
    Last Post: 8th November 2010, 13:47
  3. remote central locking doesnt work!!!!!!
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th August 2009, 08:32
  4. warranty work paper work ???
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2008, 00:21
vectra c central locking working from door button but not key
my key isnt working on my vauxhall signum
how can you tell if vectra c remote is working
my opel vectra c key doesnt work
help lock button broken on my vectra c key
my remote lock and key dont work the central locking in my Vauxhall Vectra
06 Vauxhall Vectra central locking does not work in door or remotely
vectra c sometimes central locking doesnt work
vectra c door lock key doesnt turn
central locking on vaxhall vactra stop working
how can see the key sensor on vectra c
