Thread: spanner light
    Regular Member justyb's Avatar
    wigan
    Default spanner light
    Hi all got a spanner light come on only when ignition is on once started goes off its in the little box were it shows if the door is open only just come on car seems to be runnin fine thou any ideas
    Regular Member j13hdb's Avatar
    Nottingham
    Get the stealer to plug his box of tricks in to it> he can fin the cause and clear it. Could need a service or anything!
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Is it this one:
    Indicates a service is due (or a service was done but the light not reset). If service completed you can reset it here.
    (it might say INSP instead of mileage, or just have spanner/oilcan, can't remember exactly)
    Winchester
    or this one:
    Indicates a Fault code stored in ECU. If it disappears on start-up I think the fault is no longer present. Something like 20 or 30 starts without the fault re-currring causes the light to be permantly switched off. If it keeps coming back, take to a dealer to get the fault code read.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
