Results 1 to 10 of 14
Thread: FAO fenderguitar
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Default FAO fenderguitar
    doing my reversing sensors.
    where is the reversing light wire and where is the best earth.
    nearly there but nothing goes right for me.........
    Jun 2007
    in a white box
    anyone..............
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    Thumbs up wire
    Hi John If you open the boot on your left hand side light cluster there is a white wire with black line. I wired into this for a live. Also inside the panel are a couple of nuts about 10 mm, you can undo one of these and use as earth, scratch paintwork slightly to give good connection.Hope this helps as I've had no trouble with mine so far
    Oct 2006
    Yorkshire
    I earthed mine on the bolt that attaches the rear light cluster to the car..
    Wire info here
    http://www.vectra-c.com/forum/showthread.php?t=25101
    Jun 2007
    in a white box
    will check cheers.
    got an estate though and the reversing lights are on the boot lid, i will check now and return
    many thanks
    Regular Member wardy's Avatar
    Chichester
    John,
    Would be very interested on how it goes.
    I have also got an estate and have been thinking of fitting some. Which kitt did you get? How did you remove the bumper (or didn't you)?
    Thumbs up Sensors
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=120141109177 .here is the link where i got mine £32 incl pnp and very quick delivery.You can check my otherposts to see them fitted
    Jun 2007
    in a white box
    beep beep beeep
    all working, reversing up and down the drive like a madman...
    thanks fenderguitar
    Chichester
    Cheers.
    Will check that out later (can't get to e-bay at work).
    john, did you fit them in the bumper, or the grey strip underneath?
    Thumbs up
    Quote Originally Posted by John35 View Post
    beep beep beeep
    thanks fenderguitar
    Did you get the same sensors as myself(see my other posts),had mine on a month or more now and no problems.glad I could help thats the whole idea of this site
