doing my reversing sensors.
where is the reversing light wire and where is the best earth.
nearly there but nothing goes right for me.........
anyone..............
Hi John If you open the boot on your left hand side light cluster there is a white wire with black line. I wired into this for a live. Also inside the panel are a couple of nuts about 10 mm, you can undo one of these and use as earth, scratch paintwork slightly to give good connection.Hope this helps as I've had no trouble with mine so far
I earthed mine on the bolt that attaches the rear light cluster to the car..
Wire info here
http://www.vectra-c.com/forum/showthread.php?t=25101
will check cheers.
got an estate though and the reversing lights are on the boot lid, i will check now and return
many thanks
John,
Would be very interested on how it goes.
I have also got an estate and have been thinking of fitting some. Which kitt did you get? How did you remove the bumper (or didn't you)?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=120141109177 .here is the link where i got mine £32 incl pnp and very quick delivery.You can check my otherposts to see them fitted
beep beep beeep
all working, reversing up and down the drive like a madman...
thanks fenderguitar
Cheers.
Will check that out later (can't get to e-bay at work).
john, did you fit them in the bumper, or the grey strip underneath?
