Thread: o/s indicator on instead of o/s side light
    Aug 2007
    Warrington
    Default o/s indicator on instead of o/s side light
    Bought vectra 2 dti ls (53)yesterday. One small problem, when the side lights are switched on the off side indicator lights instead. This is an intermittent fault. A sharp wrap on the headlight lens puts it right, temporarily.
    There is also a intermittent bulb failure warning on the dashboard , possibly related to the above.
    Any help greatly appreciated
    Regular Member Karl's Avatar
    Sunderland
    sounds like a crimped wire behind the headlight, it might be earthing out on the light casing. Try removing the back of the light and freeing the cables to check.
    you have a dodgy or loose side light bulb matey. When the on-board computer is notified of the faulty bulb it lights up the indicator to compensate.
    Replace your side lights bulbs, then bobs your uncle.
    Aug 2007
    Warrington
    Default Vectra side lights
    Many thanks for your help. Greatly appreciated
    Feb 2007
    Wales
    Can anyone point me in the right direction in order to change a N/S sidelight bulb - my fat hands can't seem to get in behind the headlamp unit.......??
    Mileage : 000
    Quote Originally Posted by Welsh Paul View Post
    Have you tried removing the top half of the washer bottle filler neck, it just twists and pulls out. You shuold have more room then.
    Feb 2007
    Wales
    Thumbs up
    Thanks Ed - will give it a shot when the new bulb arrives - the local VX dealer wanted at least £50 to do the job....just ordered the bulb for £3.00....am determined to do it myself - how hard can it be...???
    Mileage : 000
    It is not difficult at all I have changed them on mine. If it takes 1/2 an hour that is about it.
  1. Side indicator
    By neilrobinson1988 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2011, 17:00
  2. Drivers side indicator light stops on?!
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2011, 21:44
  3. Light indicator on but side lights working
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th November 2008, 15:20
vectra indicator comes on instead of side light
