Thread: Strange smell
    Mansfield, Nottinghamshire
    Default Strange smell
    Hi - not sure this is in the right topic but here goes over the past two days whilst driving the Vec after I've gone a couple of miles and stopped the car stinks. It's kind of like a stink bomb / blocked drains smell.
    I'm not using the Aircon at the time and if I do turn the aircon on there is no smell coming from it.
    I'm presuming their is some filter that might be to blame - can anyone advise me what it might be?
    Also will the possibly offending filter (if it is) be replaced with a service from Vx as it's booked in next week?
    Thanks for any advice
    Mark
    [Ex]Admin Duncan's Avatar
    Look at your pollen filter and also the drain channels around that area - they can get blocked up with leaves etc. and smell.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    does the cat not stink occassionally.
    i remember i used to smell it on other cars but now thinking about it i don't smell it on the vectra.....
    Here, there and every where!
    New cats smell sometimes but they normally settle down.
    Masmit, it sounds like you need an air-con cleaner to get rid of the bacteria build up Halfords do a COMMA aerosol for the job.
    As Duncan has said too, check the pollen filter and for what it costs you might as well replace it.
    Regular Member bravocorsa's Avatar
    Jun 2007
    birm
    Thumbs up
    Hi, just an idea ! had same smell when first got my vec found out it was the washer bottle?! obviously been left/unused? so emptied and cleaned through twice, now like a summer meadow!! hope yours is as easy to sort as this
    Regular Member kns's Avatar
    Northampton
    as above mine was the same
    Feb 2007
    North west
    also eating a lot of beans and sprouts can produce this effect in confined spaces.
    But this sounds like the cat has failed to me - a bad eggs smell ?
    Larkhall
    Where abouts is the pollen filter? and is it easy to clean. my air con stinks once i switch it off and ive tried the spray thing from halfords, which made it worse......
  1. Strange smell
    By Andyjarvis in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2012, 21:31
  2. vectra 2.0 turbo strange strong smell from exhausts
    By matrix1979 in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 18:13
  3. strange smell ..
    By morri76 in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2011, 11:50
  4. Spanner Light and strange smell!!
    By neil1194 in forum Engine & Drivetrain
    Last Post: 9th February 2008, 20:42
  5. Strange smell when cold 1.9 cdti
    By sri22dti in forum Vectra C / Signum Troubleshooting
    Last Post: 16th April 2007, 12:06
