Thread: Using NXT Spray Wax
    Regular Member blr123's Avatar
    Dundee, scotland
    Default Using NXT Spray Wax
    This is contained in another "How To" but I thought that some might be keen to just use this wax so here is a how to specifically for it: -
    When applying NXT Spray Wax do it like this: -
    Fold the cloth (I would recommend a MF) twice so you have 4 layers, this ensures a thick buffer between your hand and the paint.
    Apply the wax to the CLOTH (not the paint) and DO NOT turn the cloth, then apply to paint in straight lines i.e. for the roof apply from the back to the front.
    When the whole car has been done now is the time to turn the cloth, go back to where you started and remove excess wax again going in straight lines, but this time across the roof (side to side).
    And finally take a clean cloth and buff up, this time going from back to front, this ensures an even coverage of wax.
    Note: The above is not a one step product and should be used in conjunction with other products.
    Bryan
    im gonna give this another try as ive not found it the easiest thing to use. Basically i ended up getting lots of wax overspray everywhere and ended up throwing it down the road and getting my Quick detailer out lol
    Regular Member barney's Avatar
    nottingham
    I tried it this morning...did a wonerfull job but the car still needs more work...
    Just a quick question why the straight lines?
    Dundee, scotland
    Quote Originally Posted by barney
    Hi Barney,
    If you apply polish, wax etc in straight lines it meas that you are better able to see and control it being applied evenly, this is important when it comes to avoiding streeking or what looks like "shadows" this is generally due to uneven application.
    I also mention the first application be applied in one direction then the product wiped off at 90 degrees to that then when buffing up revert back to the way you applied the product, this again helps to ensure even application.
    Hope that makes sense
    Bryan
    PS Did you remember to apply the product to the cloth and NOT the paint yeah?
    nottingham
    I did the wifes clio yesterday and I sprayed it on.. it ended up all over the place and it ended up being a right pain..but still looked good.. but by then it was dark
    I did mine today direct on to a polishing cloth and it was alot easier.
    Regular Member dazza-diesel's Avatar
    Southampton
    Quote Originally Posted by Andy
    see blr123 im not the only one .... but to be honest if i had used it in the way you said in your how 2 rather than the way the instructions said i may have got on better.... this is why blokes should not read instructions....
    Dundee, scotland
    ^^^^^ .........yeah I'll give that one Daz
    Bryan
  1. Bit of Over Spray
    By spennny in forum Bodywork & Interior
    Last Post: 9th April 2011, 19:30
  2. re-spray
    By Dwabo in forum South Central (ARO - matty2fatty)
    Last Post: 5th August 2007, 20:33
  3. which spray wax
    By scott_150cdtisri in forum Detailing and Car Care Discussion
    Last Post: 17th March 2007, 00:46
  4. how much should i pay for a spray
    By kgsric in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2007, 05:12
  5. meg. spray wax
    By daveg8843 in forum Detailing and Car Care Discussion
    Last Post: 19th December 2006, 02:37
