Results 1 to 10 of 13
Thread: How To use clay
    Regular Member blr123's Avatar
    Dundee, scotland
    Default How To use clay
    A clay bar removes all "on surface grime & dirt"
    Here are some points to remember when using a clay bar: -
    Stages, do the car in stages such as: -
    Stage 1 - Roof & bonnet (possibly front wings aswell)
    Stage 2 - Both front and rear wings
    Stage 3 - All doors
    Stage 4 - Both bumpers, sills, door mirrors etc
    Stage 5 - Glass
    Stage 6 - Lights
    Stage 7 - Wheels
    Using Clay: -
    Cut clay into 2 pieces (wrap one up & set aside)
    Flaten clay to half it's thickness
    Spray lub onto paintwork
    LIGHTLY rub clay accross paintwork (like rubbing soap over your skin)
    ALWAYS stay inside the area that has been lubricated
    At the end of each stage inspect the clay, if it's time to use a clean part DO NOT turn the clay bar (flip over) as this will "LOCK" all the clean clay in between the dirty sides.
    You must FOLD the clay so as to "LOCK" the grime & dirt in, then flaten out again and away you go.
    As a rule of thumb when rubbing clay over the car a CLEAN side of clay will ALWAYS be in contact with your hand.
    Note: should you DROP the clay bar on the ground it MUST be disgarded......binned......as it WILL have picked up debris which could scratch your paint, this is another reason for cutting the clay bar into 2 pieces.
    The stages mentioned above are only a guide, you should decide on what you see when inspecting the claybar.
    All of the above are just my opinions but I hope it's helps
    Bryan
    Regular Member MLC's Avatar
    uk
    Am I correct in thinking you can only use this once?
    Dundee, scotland
    Quote Originally Posted by MLC
    For the paint yes that's correct once only, but you can keep an old one and use it for the wheels.
    Bryan
    uk
    How often do you use it then. Seems expensive if you have to throw it away.
    Dundee, scotland
    Good question MLC...........I frogot to mention..............twice a year I do mine, and if you were to wash once a week or every two weeks then that would be enough
    Bryan
    Dec 2005
    Renfrew, Scotland
    after applying the clay, do you need to wash it off or polish it off or ?
    Dundee, scotland
    Some people do some don't..........I tend to hose it down.
    Bryan
    dumbarton scotland
    where can i buy it for and how much
    Regular Member Harry's Avatar
    Uxbridge, London
    halfords are stocking it these days and for the clay and a bottle of spray you're looking at around £13 i think.
    dumbarton scotland
    Quote Originally Posted by Harry
    cheers mate going to get some now lol give her a wash and thats the car not the mrs lol
  1. To clay or not to clay?
    By rob warrington in forum Detailing and Car Care Discussion
    Last Post: 28th December 2011, 19:13
  2. Gonna take you to a clay bar, clay bar CLAY BAR!!!
    By peppered in forum Detailing and Car Care Discussion
    Last Post: 7th September 2009, 21:11
  3. Clay - WOW!!
    By davree in forum Detailing and Car Care Discussion
    Last Post: 16th March 2009, 14:24
  4. Clay Day
    By T4M in forum Quick Photo Album
    Last Post: 6th May 2008, 19:15
  5. What Clay??
    By DeathStar in forum Detailing and Car Care Discussion
    Last Post: 27th January 2008, 23:58
