Thread: which airbag which steering wheel
    Regular Member pmw123's Avatar
    lancaster
    Default which airbag which steering wheel
    hi
    please can you tell me if i have one or two connections at the rear of the airbag i have a 2007 exclusiv 1.9cdti i am also looking for a vxr or sri steering wheel had a look on ebay and there is two for the astra will these fit http://www.showoffyourcar.com/galleries.asp?carid=2734
    cheers paul
    [Ex]Admin Duncan's Avatar
    You will have two plugs on your car. If you changed wheels to another Vectra wheel, then as long as it was a facelift wheel then you'd be okay as the airbag on the facelift wheel is slightly different to the pre-facelift (full canbus) wheel.
    If you went for an Astra wheel I think you'd need to source the Astra airbag too.
    Regular Member cameraman's Avatar
    Leicester
    I've fitted a Astra VXR steering wheel to my 56 plate Vectra Design, the airbag is exactly the same straight swap, the only difference I found was the cables for the audio controls were different but just swapped them between the steering wheels. If you post the links to the e-bay items I might be able to help.
    Have a look at mine http://forum.vectra-c.com/showthread.php?t=28528
    Melbourne, Australia
    From MY03.5, the Vectras have two-stage airbags - they therefore have two plugs. Older Vectras only have one plug.
    lancaster
    Default airbags
    cheers thanks for all your help
    paul
  1. Airbag connectors in steering wheel HOW TOO ?
    By jacko52 in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2012, 13:49
  2. Steering Wheel/Airbag Badge
    By Tam80 in forum Bodywork & Interior
    Last Post: 10th June 2011, 08:26
  3. Steering wheel - airbag???
    By John3v36 in forum Bodywork & Interior
    Last Post: 18th January 2009, 22:46
