Results 1 to 10 of 18
Thread: HID Upgrade..
    Default HID Upgrade..
    Yes, I know, we've been round the block lots of times with HID kits and the legalities of them all, but I've got a question that someone who works for Vauxhall might be able to answer...
    We all know that to be fully legal you need actual Xenon headlamps, washers, and a levelling system, and anything else could invalidate your insurance... Question is - how much would Vauxhall charge to have it installed on a Vectra C that didn't originally come with them? I appreciate you'd need to change the headlamps, add the washers, the levelling sensors, change the ECU etc, but how much would this acutally cost...?
    Any ideas...?
    Last edited by Penfold101; 19th August 2007 at 13:09. Reason: Not knowing how to use my own language...
    member of the smoke patrol 230bhp+
    no no and no
    if you ask the man that does your mot and ask what it does say about it and he will tell you its just the beam patten that has and must be there and you dont need washers or a levelling system
    it will be the length of the lamp that you put in that will change the patten of the light
    The MoT isn't the qeustion mate, it's the law according to the Department of Transport - and I'd hate to find my insurnace was invalid jsut because I'd fitted an HiD kit, even if it did pass it's MoT... The quote from their website has been on here many times before, so I won't put it on again...
    if you look on ebay there is vectra hid headlight
    i think they were around £80 each plus the lamps for them
    but do remember after you fit them it will need to be tech 2 to get all the leveling to work
    if you go the full hog there will be no probs with insurance
    but this way isnt going to be cheap
    http://cgi.ebay.co.uk/VECTRA-XENON-H...QQcmdZViewItem
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I've decided not to risk it & have orderred Philips X-treme bulbs for Hi & Lo beams - They may not be as good as HID but they're legal & both beams for £50 saves me a wedge
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Penfold101 View Post
    I think, IMO, the simple answer to that one is it will cost you nowt, as no Vx dealer will do it for you. I don't know if it is technically possible - possibly but at huge expense I reckon. Because it's not something that Vx offer, they won't have kits to do it with the exact parts and if they (the dealer) comes stuck then they won't get any support from Vx.
    There are so many things that could go wrong, in terms of it not subsequently working, that I would think a dealer will just avoid it in the first instance. It could end up costing them if they'd quoted you a fixed price and then found that there was a lot more involved, or it could end up costing you a huge amount if they were doing it on a per hour and parts basis.
    Cheers mate. I know it wouldn't be cheap, but cheaper than not having the insurance pay out if I wrote the car off... If it's too expensive I won't bother, but it's a route I'm jsut having a look down...
    The honest answer is I don't know what would be needed for a full retro-fit. Obviously the headlight units with the power packs (ballast), then I would expect different wiring looms would be needed, wouldn't have thought different ECU - just Tech 2. The washers are easily fitted as proven by Andyvec so that leaves the self-levelling part which again I would think is some parts, possible different looms and programming of body modules etc. Not sure if I've missed anything.
    Would be interesting to find out exactly what is needed - got a feeling somebody posted up before, may have been in GG's HID How 2 thread.
    Regular Member Karl's Avatar
    Sunderland
    If a car passes an MOT surely there are no insurance regulations applying as the car is road legal?
    Tyneside
    Quote Originally Posted by Karl View Post
    You would think so , but this country is up it's F'n ****
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. gid upgrade
    By booker413 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 16:48
  3. Looking to upgrade
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2010, 20:17
  4. upgrade on upgrade
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 23:27
  5. upgrade done what next ?
    Last Post: 19th April 2009, 22:46
