Thread: 120 / 150 engine and mapping
    Aug 2007
    bristol
    Default 120 / 150 engine and mapping
    I have scoured these pages to gain some info regarding re-mapping a 1.9 CDTI [120] and have read 2 pieces of information that have got me thinking :-
    1/ The 120 and the 150 engine are mechanically the same unit ( some confusion on Turbo size here) with the only difference being programme that runs the engine.
    2/ A re-map will add 35'ish brake to either engine.
    The question - Is it possible to re-map a 120 engine with the enhanced 150 programme and thus gain 65 BHP for a relitively low cost
    The 120 and 150 aren't the same engine mechanically in the Vectra C / Signum. The 120 is 8 valve, the 150 is 16 valve so sticking in a 150 map probably isn't going to get you an extra 65bhp.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    I'm no expert by any means but there are mechanical differences between the 120 and the 150 - the 120 is an 8-valve unit and the 150 is 16-valve. The engine configurations are not the same, so the starting point for enhancement is not the same for both engines.
    I'm sure the diesel experts on here will enlighten you (and probably me as well). People on here tend to go for tuning boxes for diesels rather than ECU remaps which are favoured by turbo petrolheads like me.
    Again I'm sure someone here will point you in the right direction
    Edit: thanks Duncan, you beat me to it!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Quote Originally Posted by salty View Post
    As said mate, not on the vec but the 120 and 150 in the astra are the same unit, thats where you might be getting confused.
    Here, there and every where!
    A remap on the 120 engine will give approx 180bhp. PM Brocks m8. He has a 120 remapped
    EDIT sorry 170bhp.........just found this link. http://forum.vectra-c.com/showthread.php?t=25121
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    The 8v 120PS seems to be able to produce simular torque figures to the 16v 150PS but at top end it's not quite so nimble.
    Leicester
    Quote Originally Posted by nutron View Post
    Your right it does, it is the same as the older 2.0 petrol engines from Vauxhall, the 16v always produced more power but the 8v matched it and somes times beat it on low end torque.
    Belfast
    The extra 8 valves only help cylinder breathing at high revs, so obviously low end torque is going to be the same.
    Aug 2007
    bristol
    Default 120/150
    Many thanks to all that have contributed so far. If I come up with a decent solution at a reasonable cost I will let you know.
  1. EGR Re-Mapping Out
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2013, 15:25
  2. Mapping available for the 2.2 dti?
    By Rickiek123 in forum Tuning
    Last Post: 4th December 2012, 01:23
  3. re-mapping in WM
    By bert3d in forum West Midlands
    Last Post: 24th December 2011, 16:35
  4. re-mapping ?
    By mrk in forum Diesel Engine related
    Last Post: 28th April 2010, 18:43
  5. Re-Mapping
    By pedro64 in forum Diesel Engine related
    Last Post: 30th May 2006, 15:12
