Thread: Guide to Claying
    Aug 2007
    Essex
    Default Guide to Claying
    What is "Claying"?
    Claying is a process that is new to the world of automotive detailing and has found enthusiastic acceptance. It's not hard to understand why, as its resume reads like a miracle cure, and after reading it you may think that it's too good to be true. But claying delivers.
    The clay we are talking about is similar to the toy "Play-doh" that kids enjoy although a special type is required for car detailing. It performs it's function by removing the contaminants from the surface of the paint. It works by virtue of its flexibility as it easily forms the exact contour of the surface it is in contact with. What it does for a painted surface is similar to the function of polish, but unlike polish, clay is not an abrasive. This is an advantage for the beginning or casual detailer, as no harm can be done to the paint. Claying also does not remove wax, so unlike polish, there is no need to reapply it after an application. It works on surfaces that might not be appropriate for polish, such as glass, brightwork and trim items. Claying is also relatively quick and easy when compared to a polish job. Clearly a winning situation all around!
    How to Clay
    To work with clay you will need a lubricant. Fortunately what you use is not critical and many products will work fine. Many clay kits ship with a "Quick Detailer" spray which works. Our recipe consists of a tablespoon of car wash detergent in about 20 oz. of distilled water and dispensed using a spray bottle. Others have reported that Windex and other glass cleaners work well.
    Some Experimenting
    The "baggie test" is the way to go and is recommended as an easy way to demonstrate the power of claying. Put your hand in a ordinary sandwich baggie (the thin kind, not the thick rugged ones) and spray a test area of the paint with the above described clay lubricant. Then go over the paint surface as shown with just enough pressure to get a feel for the surface. You'll detect all sorts of bumps and defects, many more than are apparent with even a close visual inspection.
    Claying is done after the car is washed, but before it is waxed, assuming that you are planning on a wax job. To use the clay, apply some of the clay lubricant to the area you are going to work on, which shouldn't be larger than about 2' x 2'. Then glide (in other words, use only minimal pressure) the clay over the surface. If the lubricant is working, the effort to move the clay over the surface will be next to nothing; you are really guiding its movement more than anything else. A lot depends on how much the clay has to pick up.
    As you progress, you'll note that the clay bar gets thinner. You'll then have to rework the bar so that it is thick again by kneading it. Some detailers like to just fold it over, the reasoning is that it will have a cleaner surface. You'll get a feel for how it is working by the way it glides over the paint surface. This "feel" will also tell you when the clay bar is losing its effectiveness (it's resistance increases) and needs to be replaced. When you are finished with a section, dry it using the same towels you use after you wash the car. It's a good idea to rinse the entire car with a hose after you are finished with the claying task. When you are finished, do the "baggie test" again. The results will be easily felt.
    Claying is an odd process. If you haven't tried it, it can be difficult to understand as it doesn't seem to conform to most of what we know about car detailing. If this is your thinking, we encourage you to give it a try. It really is easy! Many amateur detailers are a bit wary of the concept but after they try it, they are sold big time.
    A clay bar is good for about four to five treatments. This depends on factors such as the size of the vehicles and how dirty they are. One important note: if you ever drop a clay bar, you MUST throw it away. The potential for causing scratches from material it picks up is just too great. If you intend to reuse the clay bar, store it in a box or baggie to keep it clean.
    (Information retrieved from web-cars.com)
    Tyneside
    Thats a good read m8, very good.
    Mileage : 000
    At first the idea of claying is a bit daunting, but when you give it a try it is very easy realy and the results are amazing, well worth doing, I can tell you.
    Regular Member fellie's Avatar
    Lincoln
    I wouldnt call it a new process.. Ive been using it for about 4 years, on 3 of my own, and inumerable other cars
    It is as Ed says, daunting but oh so worth the effort, results rarely do less than outstand people that I show ..
    I do both of my cars with Sonus green, really fine version of clay, when required.. ( bulk purchase Meguairs last wipe from clean and shiny to make it a really cheap process.. )
    Feb 2006
    Guttedsville
    Yep. Good read that, tried claying at clean and shiny, since then I've done all of our cars, my dads jag and a Disco3!
    So easy and makes it easy to polish and wax afterwards.
    I use the Sonus green too.
    Nicking Ya Dinner.
    one cap of shampoo, top up with iron water and raid the kids playdoh
    Tyneside
    Quote Originally Posted by VauxVeteran View Post
    Nicking Ya Dinner.
    Quote Originally Posted by mark1319 View Post
    TTF
  1. New to claying
    By johnny1983 in forum Detailing and Car Care Discussion
    Last Post: 25th March 2011, 13:45
  2. A guide to claying your car
    By bobssignum in forum Detailing and Car Care Discussion
    Last Post: 11th March 2011, 18:46
  3. Claying
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2008, 16:35
  4. claying
    By swainey in forum Detailing and Car Care Discussion
    Last Post: 18th July 2008, 00:53
  5. what is claying and what does it do
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2008, 10:47
