Thread: Antenna amplifier ground location
    Melbourne, Australia
    Question Antenna amplifier ground location
    Hi all,
    Sorry if this has been covered before...
    Could someone please tell me how the antenna amplifier (pictured below) is grounded? (I would like to verify the soundness of the grounds to hopefully improve poor AM reception)
    The wiring diagrams make it look like it has its own ground, but it looks to be made of plastic.
    Thanks.
    Jan 2006
    Skynet HQ EMEC#5
    That looks like my photo from changing roof aerial, I think you will find that it earths through the body where the aerial base is fitted.
    It is a serated washer that makes contact with body.
    Quote Originally Posted by Ian T View Post
    Sorry, I couldn't remember whose photo I borrowed - I was too lazy to take my own
    I think you will find that it earths through the body where the aerial base is fitted. It is a serated washer that makes contact with body.
    Thanks Ian - is the wire from the antenna to the amplifier shielded? (I thought it looked to thin to be shielded!)
    Here's Ian T's original posting that I borrowed the image from.
    Regular Member Ben H's Avatar
    Herts\Beds Border
    It's earthed to the body as Ian says. In the loom it looks like you have the aerial coax cable (thicker grey one) and the amplifier remote (the thin one)
    AM reception is generally poor on todays stereos as the manufacturer doesn't think it's that important to the consumer and so use cheap inferior components to do the job. Infact about 5 or 6 years ago some after market manufacturers made cheap entry level cd headunits with FM only tuners to bring costs down even more.
    Update: I managed to fix my poor AM reception today. I removed and reinstalled the radio and now everything works well. Must have had a flakey antenna connection at the radio...
  1. Anyone got the VXR antenna
    By Keithy in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 00:16
  2. Can i ground my amp to the stereo ground?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2009, 17:07
  3. Sat nav gps antenna
    By bigmac in forum Parts for sale
    Last Post: 22nd March 2009, 12:49
  4. GPS antenna location
    By Big Gaz in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2008, 13:13
  5. sub and amplifier
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 7th April 2008, 22:48
