Thread: tuning box
    Regular Member justyb's Avatar
    wigan
    Default tuning box
    hi just wondering how many have these boxes fitted and what are the pros and cons on these ie do they do any damage just asking b4 1 purchase 1
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    Hi Justyb
    Have only just fitted a CRD2(07) but from researching this and other forums i have nt found anyone that has had any probs conclusivley caused by one.Some have had spanner light and smoke issues when they ve cranked the power right up tho.But what i can say is buy one and you ll be grinning from ear to ear.Mine is only set on map 4 +0 (map 1 being the highest setting and map 4 being the lowest)and it s superb The most brutal accelleration of any thing i ve ever driven.Just keeps pulling and when you "drive miss Daisy" it just feels like a a more relaxed drive.Hope this helps
    Also try this thread http://forum.vectra-c.com/showthread.php?t=5657
    Leicester
    Quote Originally Posted by justyb View Post
    The Positives
    A lower cost way to increase bhp and torque on your CDTi engine.
    Easy to fit and easy to remove, simple plug and play.
    Can swap from car to car with ease.
    The Negatives
    Not a proper way of tuning an engine, they trick the ECU into thinking fuel pressure has not been reached and tells it to increase it some more. This is where the extra power and torque come from.
    Injector timing and boost pressure are not altered.
    Not many people have had problems by using tuning box's to be fair, but persoanlly I don't agree with tuning an engine this way. In my opinion, a proper re-map is the best way to go.
    Tuning box's due to there over fueling method of power increasing, can cause the fuel system internals and inlet manifold to cack up with ****. But by using a good fuel treatment on a regular basis can limit/prevent this happening.
    Regular Member ion's Avatar
    walsall
    The above by Matt is a fair view of the pro's & cons,
    I have had a CR1 on for about for about 2yrs.
    I had a swirl valve fault about 18 months ago, I don't think the box was to blame though as this is a known fault.
    Otherwise the car has been faultless.
    I can vouch for the power, it makes the car very powerful & quite savage if you want it to be, feels like it's on steroids!
    The remaps are a much better overall package, but are more expensive.
    You pay for what you get though!
    Full Member Big Sig's Avatar
    IMO a box = problems. Although lots on here have them with no problems what-so-ever. Others have had problems and its been expensive! If its still covered with a warranty then get one, if its not, think long and hard about it.
  1. TDI tuning - tuning box thoughts so far...
    By nichols120 in forum Diesel Engine related
    Last Post: 4th February 2012, 20:48
  2. tuning box or not to tuning box that is the question
    By dazzer t in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 21:47
  3. need help with tuning box
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2010, 19:49
  4. Caterman/T-Tuning Tuning Box for 1.9CDTi 150 (Z19DTH)
    By CHRISRi in forum Parts for sale
    Last Post: 25th May 2009, 18:49
  5. Diesel Tuning UK Tuning Box FOR SALE CDti 150
    By sshooie in forum Parts for sale
    Last Post: 1st April 2008, 16:49
