Results 1 to 10 of 18
Thread: how to remove
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Default how to remove
    hi
    me again
    how is the below removed (without me needing to replace the screen as i know what my luck i like) i have removed the aerial but would like to know how to remove the base from inside and outside?
    is there a hole in the glass? or is it just bounded on either side
    many many thanks baz
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    I'm fairly certain there is a hole drilled for the cable and then they are bonded to make them weather proof.
    Prepared to be corrected though.
    spoons
    Guest
    I've had this antenna before on previous company cars and in ALL cases with myself there is no hole.
    The idea is that the cellphone waves are passed through the screen without the bases actually needing to touch each other. Which is why you have one on the outside.... and one directly opposite it, on the inside..
    So... you just need to figure how to get them off the glass without damage.
    I dont know the answer to this one ??? Sorry...
    Mar 2007
    swindon
    mmm was hoping for the no hole like you said spoons now its getting it off without damaging the glass
    wonder if heating it up might help losen the glue
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    you could try (carefully) of course the old hot water and credit card method mate im sure that will get them off no probs
    Mar 2007
    swindon
    i was thinking the other halfs hairdyer for doing the inside and yes hot water on the outside might do the trick
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    if your using hot water on the outside just make sure its a nice warm day. I can remember watching my neighbour pouring a hot kettle full of water over her windscreen to get rid of the the ice. I think you can guess what happened next.
    [Ex]Admin Duncan's Avatar
    Kerrrrrrrrrrrrrrrrrack!!!!
    As spoons said, there won't be a hole in the screen as the aerials work on an inductive process between the two plates. It would be way too risky for the installer to be drilling holes in safety glass. In fact I think if they even tried it'd just shatter.
    Regular Member eaglepva's Avatar
    Up North
    Think the aerial is just bonded to the glass using silicone,
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    I've installed a few of these over the years, (had my 1st car phone in 1987, it was in a me soupped up new escort van as well, essex lad and proud..!!!) most are just fixed with a double sided sticky pad on each part, most of them used to work on the opposites attracts method of magnet positive and negative poles rejecting each other, if you get the inner and outer parts and try to put them together you will find resistance from the magnets, im not sure sure if this has changed at all with newer ones....
  1. How do i remove...
    By OllyT in forum Styling
    Last Post: 12th December 2011, 15:08
  2. How To Remove.
    Last Post: 6th July 2011, 09:10
  3. can i remove them?
    By vectra_c_wannabe in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 19:42
  4. How do you remove.......
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 18:44
  5. How do you remove
    By Triple Trouble in forum Engine & Drivetrain
    Last Post: 31st March 2008, 19:11
