Thread: Noisy tyres
    Regular Member videodoctor's Avatar
    Blackpool
    Default Noisy tyres
    Just been in to the stealers to complain about the tyre noise that my bridgestone turanza er30's make.The guy was very pleasant and after showing him some threads from here and listening to a road test,agreed with me that they were very noisy.I am an electrician and in my job we have to take sound readings for fire alarm systems(form filling!).So i measured the sound that our Vauxhall Vivaro 1.9 diesel makes with all the tools rattling and the ladders banging on the roof.
    62db was the reading.I then measured the veccy at 40mph...guess what 62db!.
    The guy said that this would help my case with Vauxhall due to being able to write down a noise figure instead of just perceived sound.
    He said that also steel wheels(which mine are) also help resonate the sound and that alloys would be better with the new tyres.
    He's ringing Vauxhall on Monday so fingers crossed they'll listen to the main dealers and fit new tyres and alloys(i wish)
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    Hi videodoctor, you may want to check that the freq range (set on your machine) matches what type of noise you are looking for. The setting for a fire alarm will be a high ish frequency, the tyre noise (if it is a rumble) will be low frequency. If you are testing to see if the alarm will cause problems for hearing it will be looking at a around 2kHz
    Best of luck
    Regular Member Islander's Avatar
    Barrow-in-Furness
    I've got Bridgestone Potenzas on my Signum the're the same VERY NOISY!
    Blackpool
    Quote Originally Posted by Swatty View Post
    Best of luck
    The meter we use just tests general sound level.It responds to high and low frequencies and displays an analogue readout in db.
    Blackpool
    Can anyone post if they have steel wheels or alloys with their bridgestone tyres.I am just wondering if the theory of steel wheels making more noise is correct or if its just the tyres that make the noise?
    Islander,what wheels have you got?
    Regular Member ironass's Avatar
    Liverpool
    [quote=videodoctor;351155]Can anyone post if they have steel wheels or alloys with their bridgestone tyres.I am just wondering if the theory of steel wheels making more noise is correct or if its just the tyres that make the noise?
    I have 18" vauxhall alloys and have recently removed potenza's with about half the tread life left in them for exactly this reason. The stealer mechanic told me it was a tyre problem and temp fitted a set of 17's from an sri and road tested it with me to prove it. As the drive was very quiet with the other tyres I went out and bought 4 new conti sports. Not cheap!! In the tyre fitters shop they showed me the wear on the inside edge of the rear tyres was uneven, one tread block seemed to be low and the next was high all around the tyre creating a "cog" effect and it was this serration causing the rumble on the road (very loud). He also told me that it is caused by incorrect camber settings for the wheel size on the rear which should have been set when the car was upgraded to 18's in the showroom. My new tyres have now started to exhibit this wear already and the noise is just starting to make an appearance, so guess where I'm off to on Monday? My car only has 20,000 on it btw. So in answer to your question, I don't think the wheel material makes much difference, I can't imagine the noise being any louder than it was with my potenza's
    Larkhall
    My old steelies had Bridgestone's and yes, they were very noisy. I didn't realise until i switched to alloys how noisy they were!!!
    Barrow-in-Furness
    Quote Originally Posted by videodoctor View Post
    18" 11 spoke alloys
    Regular Member Adam's Avatar
    Dunstable, Bedfordshire
    Cheap crappy mid-to-low end ones here. Silence
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Here is some info on noise and comparing it to everyday sound levels we hear.
    Environmental Noise
    Normal conversation (3-5') 60-70dB
    Telephone dial tone 80dB
    City Traffic (inside car) 85dB
    Train whistle at 500' 90dB
    Subway train at 200' 95dB
    Level at which sustained exposure may result in hearing loss 90 - 95dB
    Power mower 107dB
    Power saw 110dB
    Pain begins 125dB
    Pneumatic riveter at 4' 125dB
    Jet engine at 100' 140dB
    Death of hearing tissue 180dB
    Loudest sound possible 194dB
    So I would say that your 62 dB measurement is very quiet for the inside of a car. What weighting did you use??
  1. Very noisy tyres!!!
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2011, 12:34
  2. Noisy Tyres
    By SCOTTEX in forum Suspension, Wheels & Brakes
    Last Post: 22nd December 2007, 16:55
  3. noisy tyres or something else
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2007, 17:07
  4. Noisy tyres
    By videodoctor in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2007, 19:39
  5. Noisy Tyres ?
    By Dave F in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2006, 22:54
