Thread: Towed home with leak (1.9CDTI 150)
    Regular Member vcdti's Avatar
    Herts
    Default Towed home with leak (1.9CDTI 150)
    Noticed a smell of diesel driving along and then see smoke from behind, stopped to take a look and thick smoke coming from under the bonnet
    Called a local recovery firm who just got me home, now the smoke has cleared i can see everything is covered in diesel and the area the injectors are in are full of diesel, injector leaking possibly or just spray from elsewhere? anyone know a common leak fault like this?
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    on my old old astra diesel estate, diesel just pi$$$$$$ed out from what looked like a valve cap, and went all over the engine at the front, this probably doesnt help you much but i just remembered about it.....sounds like a loose injector to me
    Midlands Mod Shop - NFFC.
    Herts
    Just had a clean up and started her up, this is where the leak is coming from,
    any ideas what it is?
    Herts
    Well ive tightened this up as it was loose, leak has almost stopped just a very little dampness when running.
    Now im trying to get a new union bolt thingy but vx will only sell me an injector for £300 even thou this just unscrews.
    Please anyone have any ideas, £300 seems a bit steep for a simple bolt replacement
    northampton
    would of thought you could get the injector serviced. Not sure how much though....
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Looks like the alloy under the union has had a bit of a wack or is it a trick of the light?Seems like nice new shiney metal to me could this be related to the leak?
    Belfast
    Looks like the injector spill pipe?
    Herts
    it is just the inlet for the injector, the pipe uscrews then this little thing unscrews, but it comes with an injector cant get it seperate!
    Is it true that these common rails run at 26000psi ?? puts my karcher pressure washer to shame!
    Quote Originally Posted by IamtheStig View Post
    I thought the same, trick of the light
    Herts
    For information only, conclusion
    The union was the fuel inlet on injector, once unscrewed i found a copper washer, replaced it and leak sorted. didnt need a new injector after all
    morton
    them numptys at VX would of known that !! but still charged you for a new injector !! T****RS !!
  1. 1.9cdti fuel filter housing leak ?
    By john1 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 18:41
  2. 1.9cdti fuel pump leak
    By Ninj in forum Engine & Drivetrain
    Last Post: 20th July 2012, 21:17
  3. Heeeeelp me please 1.9cdti - changed thermostat now limp home!!
    By Damwee in forum Vectra C / Signum Troubleshooting
    Last Post: 5th September 2011, 10:57
  4. Simple 1.9CDTi Oil Leak Question from Mechanical Muppet
    By SandyGBR in forum Engine & Drivetrain
    Last Post: 14th August 2009, 10:21
  5. Slight oil leak, 1.9CDTi.
    By pricey in forum Engine & Drivetrain
    Last Post: 22nd May 2008, 19:28
