Thread: creaking clutch pedal
    northampton
    Default creaking clutch pedal
    I have the creaking clutch pedal problem. Tried the spraying of lube but no luck. Has anyone had any success in solving this one?
    Thanks in advance...
    Regular Member rickyroo's Avatar
    shropshire
    Try The Spring Sometimes It Bends Or Stretches To Much
    Bristol
    Vehicle : CDTI 150
    Hi North,
    Put up with this fault for about 12 mths, had the entire pedal box replaced under warranty. That cured it.
    Mine is a 05 plate 1.9 CDTI 150
    Northampton
    Engine : A20DTH
    Mileage : 88000
    May be a broken spring, depends on what year your Vectra is. There is a modified part to fit which costs about £6-8 if I remember. This is a known fault but they will never point it out to you at Vauxhalls. My local dealer tried to flog me a new pedal housing at over a £100. When I told them I wanted the mod he went a bit white as if he had been caught out!
    If it is the spring get is sortd asap as it will cause wear on the clutch.
    dudley
    Default Rumbling Clutch Pedal Vectra 1.9cdti 2007
    I Have A Noisy Clutch Pedal, But Only When Moving Away In First Etc. Moving The Pedal With The Engine Off, It Makes No Noise. I Have Come To The Conclusion That The Noise Is Coming From The Release Bearing/clutch And Transmitted Through The Hydraulic Fluid, Much Like A Stephascope Works?
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Creaking clutch pedal
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2012, 12:12
  3. Creaking clutch pedal
    By Marky in forum Troubleshooting
    Last Post: 20th June 2011, 08:40
  4. Creaking clutch pedal
    Last Post: 10th June 2009, 20:23
  5. Clutch pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 23:53
