Thread: Faults Logged
    May 2007
    Doing stuff
    Default Faults Logged
    Yesterday I had the spanner symbol up in the tacho, car running fine. Stopped and started again the spanner appeared on start up only car still running fine. Next journey no spanner ? went over a pot hole spanner on again.
    So I had the bonnet up and pushed all electrical connections ( i could see) together and all fuses and relays pressed in. This morning no spanner, also no DAB presets on radio.
    Does the ECU record all the faults and for how long.
    Full Member Big Sig's Avatar
    Yes it does for about 25 restarts of the engine or something similar. Have you checked the battery and ecu connections?
    May 2007
    Doing stuff
    Cheers, I did not check the battery connections or the ECU.
    Where is the ECU located ?
    Depending on your engine I have no idea! If its in the engine bay then its a silver metal box with loads of wires going to it. DO NOT disconnect these cables. Just check they are tight.
  1. HID faults - yes / no?
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 21st March 2011, 14:51
