Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: Replacing Board Info Display (BID) with Color Info display (CID)
    Regular Member grigs1's Avatar
    Aug 2007
    Bucharest
    Default Replacing Board Info Display (BID) with Color Info display (CID)
    The CID has a second socket with 20 pins in addition to primary 32 pins socket. What is the meaning of this socket? Is the cable available in my car from ECU? My understanding was that the CID shall be connected to ECU through RGB cable. Is it true? What I should do to replace the BID with CID. I have CDC 40 Opera.
    Thanks.
    Feb 2006
    Dorset
    2nd cable with 20 pins is for the sat nav display , if you aint got it dont use it , the display will work
    Aug 2007
    Bucharest
    Thanks for your information.
    I've one more question.
    Is there any possibility to connect a PDA to CID and CDC 40 Opera? I thinking that can be very interesting to see on CID the video output of the PDA or to connect a video receiver (DVB).
    The link below presents a demo with a laptop connected to CID.
    http://www.youtube.com/watch?v=PcxfIC81zaI
    Any comments. Thanks.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Quote Originally Posted by grigs1 View Post
    I have only heard of one guy who did this and that's the German Hardwarekiller
    Aug 2007
    Bucharest
    The guy from Hardwarekiller added other LCD entrance through several relays. I found that the CID includes a standard LCD so I can connect a RGB adaptor. I’m thinking why is not possible to use the 2’nd socket of GPS for Video input – RGB. My player doesn’t support the Navi, so the 2’nd socket of CID is unused. Does the CD NAVI player transmit the GPS images through a standard RGB cable to CID (2’nd socket)?
    Thanks.
    Regular Member chrisschild's Avatar
    May 2006
    Wiltshire
    Vehicle : Vectra Hatchback
    Engine : 2.2 DTi
    I was looking into something like this. As I have a rear viewing camera, so I was thinking with the colour screen I can view the fuel figures (as on the nav), but then at the flick of a switch or reverse gear, the video from a RCA signal lead is displayed?
    Also, does anyone have a wiring diagram for the normal display (I have the high res screen).
    Apologies for thread hi-jack!
    EDIT: Just spotted above link by sig63, there is a diagram, but in german!
    Aug 2007
    Bucharest
    I came back after long time period. During this time I worked to implement the video interface for cid. Currently, I finished the interface and I'm going to attach it to CID. Also, I'm going to install a rear video cam and DVB-T.
    The video interface has 3 composite video (CVBS) inputs where you can attach a rear video cam and other video devices.
    I'll post for you several pictures. The video inputs are selected by a push buton.
    Aug 2007
    Bucharest
    Surrey
    Did you ever finish it? Like to see some pics.
    Sunny Dartmoor
    That looks impressive........
  1. Info Display (??)
    By JustChris in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2012, 11:52
  2. Info' display
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2008, 17:53
