Thread: Tom Tom external antena
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    Default Tom Tom external antena
    Just need some advise on fitting , i was thinking of fitting it permenantly outside as i dont get much joy with it inside since the heat reflective screen was fitted
    steve
    Apr 2006
    Wigan
    anyone!! please
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    I've got a navman. First few pics are of me Sat nav if this helps:
    http://forum.vectra-c.com/showthread.php?t=13133
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Where you positioned the Tomtom unit?
    Mines bottom of the A pillar, just above the dash. I have no problems with getting a signal.
    Personally, I wouldn't like to have the aerial permanently on the outside, as it would be too attractive to any chav hanging around.
    Like Brocks idea of 'hiding' it under the boot lid overlap area when not in use. But, if you 'suddenly needed' the Nav, then you'd be stuffed.
    I was wondering if the unit would work tucked under the skuttle panel between the wipers. Then it would be permanently hidden, but permanently working. And the skuttle panel wouldn't block the signal, as it's only plastic.
    Feb 2006
    Dorset
    Look at your screen at an angle you should see that the area above the rear view mirror has not got the coating , double side the antenna up there
    Regular Member Damian's Avatar
    Market Drayton
    I have my TomTom GPS Receiver screwed to the underside of the parcel shelf, I still get a great signal
    You can just see the mount for it in the top right of this picture. The TomTom was taken out for valeting, but it is permanantly left in there and connected to a switched live so whenever I turn my engine on I always have my GPS up and running
    Apr 2006
    Wigan
    thanks for the options chaps
  1. External temperature Gauge
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2013, 12:37
  2. External Lighting
    By philc1210 in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2012, 09:15
  3. V6 external oil coolers
    By Leigh16v in forum Tuning
    Last Post: 10th January 2010, 16:33
  4. External Drive
    By spennny in forum General Chat
    Last Post: 7th April 2009, 15:23
  5. CD70 external in
    By mjhayward in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2007, 08:56
