Thread: Changing Front Brake Discs
    Regular Member rozzer1976's Avatar
    Feb 2007
    Lanarkshire
    Vehicle : Vauxhall Astra
    Trim : SE
    Engine : 1.7 ecoflex cdti
    Year : 62
    confused Changing Front Brake Discs
    Hi Guys and Gals,
    Can anyone out there help ! ! ! !
    Im changing the front brakes on my 2.2 dti and have encountered a problem!
    I got the pad carrier off having removed the clip and 2 bolts. My problem is thus however. What size and type of socket do i need to remove the old discs? I suspect it to be a Torx socket held by 2 bolts but dont know the size. Also, once ive removed these bolts will i require to remove anything else or is it plain sailing from there? Apologies for being a novice and thanks in advance!
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    Once you've removed the 2 torx bolts then its just a allen key small bolt holding the disc in place to the hub... Cant quite remember wot size torx socket it is now for the caliper carrier..
    gonna run out and see if i can find out...
    on 2nd thoughts its been pee'ing it down ground is all wet. will look in the morning before work for ya unless GSi3.2 comes along..
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    looky here pad change
    That was just pads though, not discs.
    As Plasma said, it's just a couple of Torx bolts - think they are T40 or T45 from memory - and then the small allen key bolt holding the disc in place.
    Make sure you give the face of the hub that meets the disc a good going over with a wire brush to clean all the rust etc. off and that you clean the new discs with brake cleaner to remove the layer of oil they apply to stop the discs rusting in storage. (Apologies if you knew all that last stuff and I'm stating the obvious. )
    Feb 2007
    Lanarkshire
    Trim : SE
    Year : 62
    Thanks for the advice guys,
    A friendly Vauxhall dealer has kindly lent me the torx socket for me too try so will change them on Sunday...fingers crossed.
  1. Changing brake discs?
    By amen in forum Handling & Braking
    Last Post: 16th July 2012, 20:33
  2. Front brake discs
    By baluachrach in forum Suspension, Wheels & Brakes
    Last Post: 19th June 2010, 22:10
  3. new front brake discs?
    By kev bux in forum Handling & Braking
    Last Post: 19th October 2007, 19:33
