Thread: Wiring amp to boot
    Vec-C Facebook Admin thegoldenbullet's Avatar
    Mar 2007
    Grimsby, Lincs.
    Default Wiring amp to boot
    hiya!
    anyone got a diagram or a how 2 on how to wire the amp, i mean where to feed the cables.
    cheers
    Russ
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Take out the glove box and you will see a large rubber grommet, just pop the live through there then feed it under the trim that holds the carpet to the side of the car. Make sure you feed the audio wires from the HU down the other side though so you don't get interference. A Ground can be found in the boot on and bolt. HTH
    Mar 2007
    Grimsby, Lincs.
    cheers buddy
    Vehicle : SRi
    Mileage : 137000
    No probs.
    Jul 2006
    I did a how2 for this m8...here
    HTH
    Regular Member Karl's Avatar
    Sunderland
    and make sure you don't run your RCA cables and power cables together, increased chance of interferance (even with shielded wiring)
  1. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  2. Is there wiring in the boot of a signum for a power outlet?
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2012, 19:40
  3. Wiring in drivers side boot compartment?
    By V6 Turbo Elite in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2011, 12:59
  4. wiring from bumper into boot???? HOW
    By degsy1234 in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2011, 06:54
  5. Boot Area Wiring
    By leeds vectra in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2007, 18:17
wiring for amp vectra c
https:www.vectra-c.comforumshowthread.php28740-Wiring-amp-to-boot
