Thread: signum 19cdti elite
    Aug 2007
    somerset
    Default signum 19cdti elite
    picked up car this tuesday looks and feels ok apart from a couple of things that im wondering if any of you guys can sort....dont like booking car in if theres some 'easy fix' diy style......1st off is this little annoying judder at certain throttle positions...car goes very well but jerks quite noticably............other thing is cruise control.....never had it before and ive read the handbook but either im not doing it right or it just dosent work dont know...theres no lights on dash to say weather its on or not.....hope someone can shed some light on it.....just dont like the hastle of booking car in......cheers.....
    Regular Member Islander's Avatar
    Barrow-in-Furness
    I have judder / misfire between 1500 - 2000 r.p.m. seems to be quite common
    on this engine can usually manage to drive through the problem by shifting up
    or down a gear. To set the c.c. press the upper part of the button ( this also
    increases the set speed once the c.c. is engaged, the lower part of this button
    when pressed decreases the speed ) to cancel press the inner section nearest the dash, touching the brake or accellerator also cancels the c.c.
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Also, if you use the bottom part of the cc button to turn it on, it automatically goes to
    the speed that was set before it was last cancelled.
    Regular Member Karl's Avatar
    Sunderland
    Cruise control should come up on the dash as a green icon showing a speedo.
    You can't have the cc working unless you have hit the brake pedal and be over 30mph. Also, if the car is a manual I would try lifting the clutch pedal with your foot to make sure it doesn't have a loose clutch pedal.
    Try running some injector cleaner through the car to make sure it isn't just a touch clogged up. It may have been sat on the forecourt for a while and need a blow out to get it back to form.
    Regular Member chinky's Avatar
    midlands
    i get infrequent judder at tick over if i switch off i get a little overburn/run and switch back on and all is fine then a week later same again though i think it might happen after ive booted it a little but aint certain
    Regular Member dave45040's Avatar
    llandudno
    Quote Originally Posted by hovis007 View Post
    Hi and welcome - got any pics of your new motor?
  1. Off to look at a Signum Elite. Elite + suspension = GSI?
    By Yugguy in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2012, 10:42
  2. Signum elite
    By lukesignum in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2009, 10:23
  3. rocker cover gasket signum 19cdti 150 (56)
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2009, 22:13
  4. signum 19cdti 150
    Last Post: 23rd April 2009, 22:03
