Results 1 to 10 of 11
Thread: Vacuum between Glass
    spoons
    Guest
    Default Vacuum between Glass
    Someone mentioned to me yesterday that the 'vacuum' in double glazed windows wears off over a period of years... therefore noise reduction is also reduced significantly.
    Can you 'reset' the vacuum within your existing double glazed windows or does it just mean that you have to replace them all.
    Also, how do you tell how good the vacuum is ?? (no sarcastic comments... oh, go on then....)
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is it actually a vacuum? Or is it filled with inert gas? If it is actually a vacuum, then the forces pushing the glass panels together would be HUGE.
    Can't really see it being a vacuum.
    EG, Force = pressure x area
    Pressure = 100,000 Pa (N/m2)
    Area = 1m2 (for a large single piece - lets just say)
    The sealed units can be removed and replaced, without changing the frames. Never heard of sound proofing 'wearing off' after a few years TBH
    Force = 100,000 N = = = 10 tonnes of weight approx. Glass would smash.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Dont think it's the 'vacuum' but the seals which break down/deteriorate. I agree with Ste don't think it's a vacuum anyway, but I'm not sure.
    May 2007
    Doing stuff
    I thought it was just a sealed unit filled with air or an inert gas, not a vacuum. The seal can deteriorate and moisture become evident in the air space.
    The thermal performance and sound proofing is due to the air gap.
    I am no expert but thats my penny's worth.
    spoons
    Guest
    Wikipedia...
    The air space between the lites may be filled with air or an inert gas like argon or krypton which would provide better insulating performance.
    Typically the spacer is filled with desiccant to prevent condensation and improve insulating performance.
    Less commonly, most of the air is removed, leaving a partial vacuum, which drastically reduces heat transfer through convection and conduction. This is called evacuated glazing.
    .......so the chances are that I've just got air between the lites and my source information was not correct !! there is no vacuum..
    Basically once the sealed unit has lost it's seal - and either the partial vacuum or the inert gas in it - it's a new sealed unit. I've never heard of anyone refilling the gas or redoing the partial vacuum.
    As for telling how good the seal/vacuum is - I don't think you can. One symptom of a sealed unit failing is you start to get condensation between the two panes. Other than that I don't think you can really test it as such.
    Regular Member SignumPhil's Avatar
    Luton, Beds
    That's what I thought (having bought new windows recently). They theoretically fill the space with dry air, and the seal has a desiccant in it, to keep the air dry.
    If the unit leaks (I believe "blown" is the technical term) damp air gets in, saturates the desiccant and you get condensation inside.
    Any repair you could do with be harder and more expensive than a new unit.
    If you have to replace it, I'd go for Pilkington K glass, to give better unsulation.
    Phil
    Here, there and every where!
    I've just had both panes in the front go and they are starting to condensate up! SWMBO now thinks it would be a good time to change the windows as they have been in for all of 14 years. I said "but they're plastic!" No matter, she'd like a "change" Women!
    By the way they used to fill the gap with "stale air" and desiccant around the edge. ( i sold windows for a short while a few years ago ) No vacuum Not sure if it's still the same
    Regular Member G.O'Rilla's Avatar
    Jul 2006
    On the road
    The only vacuum in our house is the one between my ears. They give me a brain scan every 6 months to prove it............
    Regular Member simac's Avatar
    Wirral
    Aye, that's the only way to tell seals have failed TBH even then the condensation will only appear during certain climatic conditions. Changing the units is the most economical way to sort it out, while retaining the existing frames.
    Also, you would struggle now to find a double glazed unit which isn't K seal (well, the outer pane) as this is a Building Reg requirement which all of the manufacturers, to my knowledge, apply to all their products.
    Normally hardwood double glazed units fail earlier than uPVC, i've seen some poor quality h/w windows fail at 6 years old.
  1. Vacuum level.
    By carling in forum Engine & Drivetrain
    Last Post: 12th January 2013, 10:54
  2. oil vacuum
    By Al 22 dti in forum The 'Off Topic' room
    Last Post: 16th February 2012, 12:12
  3. AFR & vacuum gauge 3.2
    By TimTay in forum Styling
    Last Post: 14th November 2011, 01:40
  4. vacuum
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 17:59
  5. vacuum solanoid
    By cooki in forum Engine & Drivetrain
    Last Post: 3rd July 2009, 22:06
